3845 DRAM
Anyone know what kind of DRAM memory compatible with 3845?
DIM ECC?
7 Replies 7
sakella
For 3825
• Default: 128-MB Compact Flash; 512-MB DDR SDRAM
• Maximum: 512-MB Compact Flash; 1-GB DDR SDRAM
For 3845
Here is a document
http://www.cisco.com/en/US/partner/products/ps5855/products_data_sheet0900aecd8016a8e8.html
thanks for the response Sakella
but i'm talking about RAM memory, no about Flash memory
bolick
For 3845 you have a few options in terms of upgrades and spare modules.  I'm assuming you're asking about a field upgrade so you would be interested in these modules:
MEM3800-256D=               256MB DIMM DDR DRAM for the Cisco 3800 Series
MEM3800-512D=               512MB DIMM DDR DRAM for the Cisco 3800 Series
These are the only memory modules officially supported by Cisco.
Can i use a non-cisco RAM memory...?
Someone tested it before?
Will it work? Possibly.
Is it supported?  Absolutely not.
Could it cause the router to crash and generally not be a happy camper? Possibly.
Another concern for non-cisco memory is an RMA.  If later this router is returned under RMA and is received with the third party memory installed, you can be billed full price for the Cisco memory shipped on the RMA.
Thanks for the replies.
I have to buy Cisco Memory
