CBAC firewall access list
garynicklaw
I need help to configure the access list on the outbound internet port to accept the following:
ip access list 10
access-list 10 permit PPTP vpn any xxx.xxx.xxx.xxx
access-list 10 permit RDP any xxx.xxx.xxx.xxx
access-list 10 permit FTP any xxx.xxx.xxx.xxx
access-list 10 permit Postgresql any xxx.xxx.xxx.xxx
access-list 10 permit MacARD any xxx.xxx.xxx.xxx
This method does not work on the Cisco 2921 router with FW
Any help is greatly appreciated
GJN
Richard.H.Sims
So you've done "access-group 10 out" on the interface facing the internet and it's not working?
Are you wanting to make it so people can connect in from the internet to your local machines for services like FTP or PPTP?  At the moment your ACL looks like it allows people from inside the network to connect to FTP/RDP servers on the internet.
ACLs with numbers below 100 are called 'Standard' and are as follows:
Access-list
Source address being where the packet is coming from.
You need to make an extended access list if you want to block or allow specific protocols.
http://www.cisco.com/en/US/products/sw/secursw/ps1018/products_tech_note09186a00800a5b9a.shtml#extacls
Hopefully that'll help.
