3945 router will not boot
Frank5by5_2
I have a router I was working on that has suddenly started to boot into ROMMON.
I'm getting:
Readonly ROMMON initialized
rommon > 1
I can see the IOS file when I do a "dir flash0:"
that tells me the flash is acknowledged and read by the router.
I have used a known good flash and the router wont boot from it either.  I can use the flash from the failed router to boot another identical router just fine.
I have looked at other forum discussions which has led me to ensure the CF is firmly seated, and the DIMMs as well.
Am i jumping the gun to think I havea router hardware problem?
Any ideas would be appreciated
Hi Frank,
*** Machine Check Exception ***
System Return Info:
count: 19, reason: reset
pc:0x0, error address: 0x0
Stack Trace:
FP: 0x00000000, PC: 0x00000000
Based on the above it is confirmed that there is a Hardware issue with the device & requires replacement. Kindly do the needful.
***********Plz do rate this post if you found it helpful*************************
Thanks & Regards,
Vignesh R P
8 Replies 8
Richard Burts
One idea is that it may be an issue with the config register. If you can get the router to boot using the image in flash it would be helpful if you would post the output of show version. The value of the config register is in the output near the last line.
Rick
Rick
jawad-mukhtar
Level 4
Level 4
Please change configuration register value to
0x2102
confreg 0x2102
Jawad
Richard and Jawad,
Thanks for your replies.  I have set confreg to 0x2102 and rebooted, but the problem still remains.  I have noticed that when the IOS attempts to launch the configuration register confirms that it is set to to 0x2102.
I'm really leaning toward a HW problem as the CF works in my other router.  There really isn't anything else configurable unless there is a possibility that the speed setting in the configuration register is not in the 0x2102 parameter, However, if it's not, I dont know how it would have changed, this router worked last week.
might there be a configiguration register speed setting that I can check?
I really appreciate your ideas
Frank
Post the entire bootup process.
Frank
I am not sure what speed setting you are thinking about. The obvious one is the console speed. That speed is set in the config register - and the fact that you are getting console output showing that you are in rommon verifies that the console speed setting is correct.
I agree with Leo that you should post the entire bootup process output.
Rick
Rick
Richard, Leo,
Here is the Boot up:
System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
Copyright (c) 2012 by cisco Systems, Inc.
Total memory size = 1024 MB - DIMM0 = 512 MB, DIMM1 = 512 MB
CISCO3945-CHASSIS with C3900-SPE150/K9 with 1048576 Kbytes of main memory
Main memory is configured to 72/72(dimm 0/1) bit mode with ECC enabled
program load complete, entry point: 0x4000000, size: 0x18fa0
IOS Image Load Test ___________________
CPU context of the most recent exception:
R0   = 0x3ccadba1 R1   = 0x00413564 R2     = 0xff9ab7fa R3     = 0x3ccadb80
R4   = 0x00413658 R5   = 0x00000080 R6     = 0x8bb86f66 R7     = 0x00929857
R8   = 0x974c3ea0 R9   = 0x00413678 R10   = 0x004132d4 R11   = 0x3ccadba0
R12   = 0x5c6f132d R13   = 0xfd7dd3f2 R14   = 0xdf6d7eff R15   = 0xffba0710
R16   = 0xea3feb97 R17   = 0x7c7eccb1 R18   = 0xfffceebd R19   = 0x5eb6bc14
R20   = 0xfb36bfff R21   = 0x0ecd5edf R22   = 0xdaaf5cec R23   = 0xd23de653
R24   = 0xf53e6bbc R25   = 0xcfbaf9cf R26   = 0xff5cdde5 R27   = 0xff2c1d1e
R28   = 0xff8e7560 R29   = 0x00000000 R30   = 0xfd7fbffd R31   = 0x00413564
CR   = 0x88000082 LR   = 0xff84bba8 CTR   = 0xff84ba34 XER   = 0x20000000
TBU   = 0x00000000 TBL   = 0xde49e93e DEAR   = 0x00000000 IVPR   = 0x00000000
PVR   = 0x00000000 DBCR0 = 0x00000000 DBCR1 = 0x00000000 DBCR2 = 0x00000000
IAC1 = 0x00000000 IAC2 = 0x00000000 DAC1   = 0x00000000 DAC2   = 0x00000000
CSRR0 = 0x00000000 CSRR1 = 0x00000000 MCSRR0 = 0xff84ba88 MCSRR1 = 0x02029200
PC   = 0xff84ba88 MSR   = 0x02029200
CPU SPR Registers:
CSRR0 = 0x00000000
CSRR1 = 0x00000000
CTR = 0xff84ba34
DAC1 = 0x00000000
DAC2 = 0x00000000
DBCR0 = 0x00000000
DBCR1 = 0x00000000
DBCR2 = 0x00000000
DBSR = 0x20000000
DEAR = 0x00000000
DEC = 0x00002b50
ESR = 0x00000000
IAC1 = 0x00000000
IAC2 = 0x00000000
IVOR0 = 0x00000100
IVOR1 = 0x00000200
IVOR2 = 0x00000300
IVOR3 = 0x00000400
IVOR4 = 0x00000500
IVOR5 = 0x00000600
IVOR6 = 0x00000700
IVOR8 = 0x00000c00
IVOR10 = 0x00000900
IVOR11 = 0x00000b00
IVOR12 = 0x00000d00
IVOR13 = 0x00001400
IVOR14 = 0x00001300
IVOR15 = 0x00001500
IVPR = 0xff800000
LR = 0xff83f630
PIR = 0x00000000
PVR = 0x80210030
SPRG0 = 0x00413658
SPRG1 = 0x00413658
SPRG2 = 0x00413658
SPRG3 = 0x00000000
SPRG4 = 0xff84bba8
SPRG5 = 0x00000000
SPRG6 = 0x00000000
SPRG7 = 0x00000000
SRRO = 0xff874104
SRR1 = 0x02029200
TBL = 0xe75c81ab
TBU = 0x00000000
TCR = 0x04400000
TSR = 0x08000000
USPRG0 = 0x00000000
XER = 0x20000000
BBEAR = 0x00000000
BBTAR = 0x00000000
BUCSR = 0x00000001
HID0 = 0x00004080
HID1 = 0xc5021000
IVOR32 = 0x00000f00
IVOR33 = 0x00001000
IVOR34 = 0x00001100
IVOR35 = 0x00001200
L1CFG0 = 0x00383820
L1CFG1 = 0x00383820
L1CSR0 = 0x00010001
L1CSR1 = 0x00000001
MAS0 = 0x10000000
MAS1 = 0xc0000700
MAS2 = 0xff000002
MAS3 = 0xff000033
MAS4 = 0x00000000
MAS6 = 0x00000000
MCAR = 0x3ccadba0
MCSR = 0x00010008
MCSRR0 = 0xff84ba88
MCSRR1 = 0x02029200
MMUCFG = 0x000019c4
MMUCSR0 = 0x00000000
PID0 = 0x00000000
PID1 = 0x00000000
PID2 = 0x00000000
SPEFSCR = 0x00000000
SVR = 0x80e80022
TLB0CFG = 0x04110200
TLB1CFG = 0x101bc010
System Return Info:
Stack Trace:
Compact Flash1: Not present
R0   = 0x00000400 R1   = 0x00413094 R2     = 0xff9ab7fa R3     = 0x00000000
R4   = 0x00000000 R5   = 0x0001000c R6     = 0x00000000 R7     = 0x00000000
R8   = 0x0001000c R9   = 0x00000000 R10   = 0x00003f93 R11   = 0x0000019c
R12   = 0x22000042 R13   = 0xfd7dd3f2 R14   = 0xdf6d7eff R15   = 0xffba0710
R24   = 0xf53e6bbc R25   = 0x04090000 R26   = 0x0041335c R27   = 0x00000000
R28   = 0x00000001 R29   = 0x0041fb4f R30   = 0x0401cac4 R31   = 0x00000000
CR   = 0x22000024 LR   = 0x040131fc CTR   = 0x000003fa XER   = 0x20000000
TBU   = 0x00000000 TBL   = 0x1d7faed7 DEAR   = 0x00000000 IVPR   = 0x00000000
CSRR0 = 0x00000000 CSRR1 = 0x00000000 MCSRR0 = 0x04015750 MCSRR1 = 0x02029200
PC   = 0x04015750 MSR   = 0x02029200
CPU SPR Registers:
CSRR0 = 0x00000000
CSRR1 = 0x00000000
CTR = 0x000003fa
DAC1 = 0x00000000
DAC2 = 0x00000000
DBCR0 = 0x00000000
DBCR1 = 0x00000000
DBCR2 = 0x00000000
DBSR = 0x20000000
DEAR = 0x00000000
DEC = 0x0000ad86
ESR = 0x00000000
IAC1 = 0x00000000
IAC2 = 0x00000000
IVOR0 = 0x00000100
IVOR1 = 0x00000200
IVOR2 = 0x00000300
IVOR3 = 0x00000400
IVOR4 = 0x00000500
IVOR5 = 0x00000600
IVOR6 = 0x00000700
IVOR8 = 0x00000c00
IVOR10 = 0x00000900
IVOR11 = 0x00000b00
IVOR12 = 0x00000d00
IVOR13 = 0x00001400
IVOR14 = 0x00001300
IVOR15 = 0x00001500
IVPR = 0xff800000
LR = 0xff83f630
PIR = 0x00000000
PVR = 0x80210030
SPRG0 = 0x00000002
SPRG1 = 0x00000002
SPRG2 = 0x00000000
SPRG3 = 0x00000000
SPRG4 = 0x040131fc
SPRG5 = 0x00000000
SPRG6 = 0x00000000
SPRG7 = 0x00000000
SRRO = 0x04001654
SRR1 = 0x02029200
TBL = 0x2692331e
TBU = 0x00000000
TCR = 0x04400000
TSR = 0x08000000
USPRG0 = 0x00000000
XER = 0x20000000
BBEAR = 0x00000000
BBTAR = 0x00000000
BUCSR = 0x00000001
HID0 = 0x00004080
HID1 = 0xc5021000
IVOR32 = 0x00000f00
IVOR33 = 0x00001000
IVOR34 = 0x00001100
IVOR35 = 0x00001200
L1CFG0 = 0x00383820
L1CFG1 = 0x00383820
L1CSR0 = 0x00010001
L1CSR1 = 0x00000001
MAS0 = 0x10000000
MAS1 = 0xc0000700
MAS2 = 0xff000002
MAS3 = 0xff000033
MAS4 = 0x00000000
MAS6 = 0x00000000
MCAR = 0x00000120
MCSR = 0x00000008
MCSRR0 = 0x04015750
MCSRR1 = 0x02029200
MMUCFG = 0x000019c4
PID0 = 0x00000000
PID1 = 0x00000000
PID2 = 0x00000000
SVR = 0x80e80022
System Return Info:
Stack Trace:
rommon 1 >
Thanks for your thoughts and ideas on this!!
Frank
Hi Frank,
System Return Info:
Stack Trace:
Thanks & Regards,
Vignesh R P
Vignesh R P,
Thank you I appreciate your assistance.
Frank
