3G card and Roger's Wireless in Canada
I have a customer that is interested in connecting a remote office using the 3G card in a 1900 series router, but the only provider in this location in Canada in Rogers Wireless.
Can anyone suggest which card will work there if any or does Roger's sell an adaptor that could be connected to an Ethernet port on the router instead?
Thanks for the assistance.
Latchum Naidu
Hi Richard,
You need to insert the SIM card provided by the 3G provider into the PCI Express card on the router.
If the card is not available on your 1900 then you need to buy this to do the job.
I dont think there is any converters or something to connect into Ethernet port.
Please click on the correct answer on all posts if they answered your question.
Naidu.
