3M ATM IMA
majedalanni
Hi,  I have Cisco router 1921 with VWIC2-2MFT T1/E1, and I got WAN connection 3M ATM IMA. Is VWIC2 card will work? If yes how I configure it and if no what card should I buy?  Thanks in advance!  Mike
Roman Rodichev
Level 7
Level 7
in the past they had an aim-atm module that went inside the router but I'm pretty sure it's not supported in 1900. the last router that supported it was 2800.
So did u mean ATM IMA NOT working with 1921 at all? Or there should another card that support it   Mike
Correct, there is no support whatsoever for ATM IMA on the ISR G2.
