4321 router boot problem
hi,
suddenly I ahve problem with router after power outage .... stuck in loop. Any way out of this?
Initializing Hardware ...
Checking for PCIe device presence...%ERROR: Critical device not found on 00:02.00
done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.12(2r), RELEASE SOFTWARE
Copyright (c) 1994-2019 by cisco Systems, Inc.
Current image running: Boot ROM1
Last reset cause: PowerOn
ISR4321/K9 platform with 4194304 Kbytes of main memory
Located isr4300-universalk9.17.03.02.SPA.bin
Package header rev 3 structure detected
IsoSize = 664567808
Calculating SHA-1 hash...Validate package: SHA-1 hash:
calculated F3FF0447:89E51AF9:91BB1CD5:5712C15F:7CFE1C5D
expected F3FF0447:89E51AF9:91BB1CD5:5712C15F:7CFE1C5D
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
%IOSXEBOOT-1-INVALID_IMAGE: (RP/0): Incompatible hardware and software image version; newer software version required.
done
Last reset cause: LocalSoft
IsoSize = 664567808
Image validated
done
17 Replies 17
balaji.bandi
Go to ROMMON and check by issue dir  ( do you see any other images in the flash?)
Other hand Looks like the image invalid ? do you have any older version IOS , then copy in to USB and get on to ROMMON and Try to boot.
BB
hi,
I tried dir and I can see two images ... tried to boot older one but problem is the same
post dir output here.
BB
rommon 1 > dir bootflash:
0 550119351 -rw- isr4300-universalk9.16.06.04.SPA.bin
0 0 drw- .installer
0 34 -rw- pnp-tech-time
0 49376 -rw- pnp-tech-discovery-summary
0 0 drw- core
0 0 drw- .prst_sync
0 0 drw- .rollback_timer
0 0 -rw- tracelogs.EoF
0 0 drw- tracelogs
0 30 -rw- throughput_monitor_params
0 703643960 -rw- isr4300-universalk9.17.03.02.SPA.bin
0 0 drw- sysboot
0 0 drw- .USWAP
0 0 drw- .CRFT
0 4956 -rw- mode_event_log
0 0 drw- gs_script
0 134458 -rw- memleak.tcl
0 20109 -rw- ios_core.p7b
0 1314 -rw- trustidrootx3_ca.ca
0 0 drw- virtual-instance
0 0 drw- vman_fdb
0 0 drw- .dbpersist
0 0 drw- license_evlog
0 0 drw- onep
0 1016 -rw- vlan.dat
0 0 drw- lost+found
Post the complete output to the command "set".
Can the router boot firmware 16.6.4?  If it can, load that.
Once it boots up, download 17.3.5 and unpack the package files in Install Mode.
Refer to Cisco ISR & ASR 1k Routers: IOS-XE/Firmware Upgrade (Install Mode).
rommon 21 > set
PS1=rommon ! >
THRPUT=
TFTP_BLKSIZE=512
MCP_STARTUP_TRACEFLAGS=00000000:00000000
TFTP_RETRY_COUNT=20
BOOT=bootflash:/isr4300-universalk9.17.03.02.SPA.bin,1;bootflash:/isr4300-universalk9.16.06.04.SPA.bin,1;
LICENSE_BOOT_LEVEL=
DEVICE_MANAGED_MODE=autonomous
RET_2_RTS=14:10:29 utc Mon Mar 1 2021
RET_2_RCALTS=
BSI=0
RANDOM_NUM=370623220
rommon 22 >
connect console (post complete output)
rommon 1 > reset
rommon 1 > confreg 0x2142
rommon 1 > boot bootflash:isr4300-universalk9.16.06.04.SPA.bin
BB
rommon 23 > boot bootflash:isr4300-universalk9.16.06.04.SPA.bin
Located isr4300-universalk9.16.06.04.SPA.bin
Package header rev 1 structure detected
IsoSize = 550114467
calculated 444F4D02:44C58887:D9C8942B:C557D3CF:2A14247E
expected 444F4D02:44C58887:D9C8942B:C557D3CF:2A14247E
Image validated
done
IsoSize = 664567808
Image validated
Where did this router come from?
Did this router come direct from Cisco or was this purchased from "somewhere else"?
:-)) cisco of course and it worked ok until this last power failure
@DraganSkundric87318 wrote:
LICENSE_BOOT_LEVEL=
Because the License is gone.
Try the following command in ROMMON:
set LICENSE_BOOT_LEVEL appxk9,appxk9:esg
WARNING:  Case sensitive.
didn't help
Raise a TAC Case and RMA the router.
WARNING:  When raising an RMA, make sure the case is queued to EMEA or NAM/LATAM desk.
Looks for me "Checking for PCIe device presence...%ERROR: Critical device not found on 00:02.00"
Due to Power Failure, something went wrong.,
Worth contacting Cisco TAC for RMA for replacement.
BB
