4331 ISR Memory Utilization in Percentage
snarayanaraju
Level 4
Level 4
Hello - I am looking for the command to find the current Memory Utilization in Cisco 4331 Router. I tried various commands. Each command gives different value. Can you please help me to find the exact way to find the Memory Utilization
rtr2#sh version | in physical
16777216K bytes of physical memory.
rtr2#
rtr2#show processes memory
Processor Pool Total: 7978781248 Used: 339887624 Free: 7638893624
lsmpi_io Pool Total: 6295128 Used: 6294296 Free: 832
rtr2#sh memory
Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 7F2D4FE4F010 7978781248 339894036 7638887212 638672408 7340031908
lsmpi_io 7F2D4F64C1A8 6295128 6294304 824 824 412
Dynamic heap limit(MB) 7000 Use(MB) 0
Thanks, Sairam
balaji.bandi
You are using correct syntax
First one shows Physcal Memory installed in the device, next 2 comands shows the utlisation.
more informaton can be find here :
https://www.cisco.com/c/en/us/td/docs/routers/access/4400/troubleshooting/memorytroubleshooting/isr4000_mem.html
BB
snarayanaraju
Level 4
Level 4
Thanks - If this below command shows the utilization, which of the two lines should be used for calculating the Routers memory utilization?
The first line shows only 339MB is used and 7.6GB is free
The second line shows only 832B is free, which sounds bad
regards,Sairam
if you issue show version will give you below example : which tell you what is your hardware installed memory.
example :
#sh ver
cisco ISR4431/K9 (1RU) processor with 1648789K/6147K bytes of memory.
Processor board ID XXXXX
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.   - 4GB RAM
6598655K bytes of flash memory at bootflash:.
show process memory command. Note that the following commands display only information that is within Cisco IOSd, and it does not indicate memory use in the Cisco IOS XE operating system.
you get what percentage memory in the kit issue below command : (the document has good information which was provided)
BB
