4431 Router issue with youtube Website
shaik.irfan.24
hi,
Lan users are not able to connect to youtube if they afer several attempts, the video is just kept buffering.
When we restart the router 4431 if works for sometime and then suddenly users cannot browse youtube.com
The router 4431 is configured with Static NAT, and access-lists.
Already contacted the ISP and they said there is no problem from their end.
what could be the issue.?
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2019.06.25 18:36:19 =~=~=~=~=~=~=~=~=~=~=~=
Current configuration : 2575 bytes
version 15.5
service password-encryption
no platform punt-keepalive disable-kernel-core
hostname xyz_ROuter
boot-start-marker
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
enable password 7 050A020228421F5B4A
aaa new-model
aaa session-id common
ip name-server 84.2.6.55 84.2.57.230
no ip domain lookup
ip domain name xyz.com.sa
subscriber templating
voice-card 0/4
no watchdog
license udi pid ISR4431/K9 sn FOC22055T8Y
username admin privilege 15 password 7 050A020228421F5B4A
redundancy
mode none
vlan internal allocation policy ascending
interface GigabitEthernet0/0/0
ip address 37.2.15.79 255.255.255.254
ip nat outside
negotiation auto
interface GigabitEthernet0/0/1
description "Connected-to-LAN"
no ip address
ip nat inside
negotiation auto
interface GigabitEthernet0/0/1.100
encapsulation dot1Q 100
ip address 10.10.10.10 255.255.255.0
ip nat inside
interface GigabitEthernet0/0/2
no ip address
shutdown
negotiation auto
interface GigabitEthernet0/0/3
no ip address
shutdown
negotiation auto
interface Service-Engine0/4/0
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
interface Vlan1
no ip address
shutdown
ip default-gateway 37.2.15.78
ip nat inside source list 131 interface GigabitEthernet0/0/0 overload
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route 0.0.0.0 0.0.0.0 37.224.15.78
ip route 10.1.0.0 255.255.252.0 10.10.10.11
ip route 10.2.0.0 255.255.252.0 10.10.10.11
ip route 10.11.11.0 255.255.255.0 10.10.10.11
ip route 10.170.252.0 255.255.255.0 10.10.10.11
ip ssh time-out 60
access-list 131 permit ip 10.10.10.0 0.0.0.255 any
access-list 131 permit ip 10.1.0.0 0.0.3.255 any
access-list 131 permit ip 10.2.0.0 0.0.3.255 any
access-list 131 permit ip 10.11.11.0 0.0.0.255 any
access-list 131 permit ip 10.170.252.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
transport input all
end
7 Replies 7
balaji.bandi
what will be interface consumption in related to bandwidth to internet.
if you get again the problem, check the interace utilisation, process information.
couple questions : how many users behind this router ? which is effecting ? what is your internet bandwidth size ?
BB
shaik.irfan.24
Hi Balaji,
1. what will be interface consumption in related to bandwidth to internet.
Ans: Consumption is around 60-70 Mbps (out of 100Mbps )
2. if you get again the problem, check the interace utilisation, process information.
Ans.
GigabitEthernet0/0/1 is up, line protocol is up
  Hardware is ISR4431-X-4x1GE, address is --------- (bia -----------)
  Description: "Connected-to-LAN"
  Internet address is 10.10.10.10/24
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
     reliability 255/255, txload 7/255, rxload 1/255
  Keepalive not supported
  Full Duplex, 1000Mbps, link type is auto, media type is RJ45
  output flow-control is off, input flow-control is off
  Last input 00:00:01, output 00:00:48, output hang never
  Input queue: 0/375/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 4953000 bits/sec, 1794 packets/sec
  5 minute output rate 31239000 bits/sec, 3152 packets/sec
     35488933 packets input, 10357813925 bytes, 0 no buffer
     Received 0 broadcasts (0 IP multicasts)
     0 watchdog, 7839 multicast, 0 pause input
     64778300 packets output, 84549865258 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     462 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
xyz_ROuter#sh processes cpu history
      11111111111111               1111111111          11111111111
  100
   90
   80
   70
   60
   50
   40
   30
   20
     0....5....1....1....2....2....3....3....4....4....5....5....6
               0    5    0    5    0    5    0    5    0    5    0
               CPU% per second (last 60 seconds)
      112222121121211211121111111122122111111111112112132111121211
  100
   90
   80
   70
   60
   50
   40
   30
   20
               CPU% per minute (last 60 minutes)
              * = maximum CPU%   # = average CPU%
  100
   90
   80
   70
   60
   50   *
   40   *
   30   *
   20   *
   10 * *
     0....5....1....1....2....2....3....3....4....4....5....5....6....6....7..
               0    5    0    5    0    5    0    5    0    5    0    5    0
                   CPU% per hour (last 72 hours)
i. how many users behind this router ?
Ans: 200
ii. which is effecting ?
Ans: Websites, Applications( Whatsapp), Youtube etc.,
iii. what is your internet bandwidth size ?
Ans: 100Mbps
balaji.bandi
Can you post show version also to look what license you have, base normally is 100MB.
post out of below :
show version
show platform hardware throughput level
below is Lan side interface information, i am more intrested to look WAN Side.
After reset the router, how long the Problem comes back ? (days or hours ?)
BB
shaik.irfan.24
Ans: The problem instantly starts.
Here is the below as requested
show version
xyz_ROuter#sh ver
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
xyz_ROuter uptime is 20 hours, 0 minutes
Uptime for this control processor is 20 hours, 1 minute
System returned to ROM by reload
System image file is "bootflash:isr4400-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
appxk9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           None             None             None
uck9             uck9             Permanent        uck9
securityk9       None             None             None
ipbase           ipbasek9         Permanent        ipbasek9
cisco ISR4431/K9 (1RU) processor with 1648789K/6147K bytes of memory.
Processor board ID FGL220880DE
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
6598655K bytes of flash memory at bootflash:.
xyz_ROuter# sh platform hardware throughput level
The current throughput level is 500000 kb/s
kapydan88
Level 4
Level 4
Hello.
Have you got problems with Youtube only? Can you see another video in real time?
Sumant Mali
In issue condition,
- Check if there are any datapath drops using "show platform hardware qfp active statistics drop" CLI. You need to execute this CLI multiple times to see increasing drops. If you see any drops increasing you can check which interface is causing that drop using "show platform hardware qfp active interface all statistics drop" CLI- again multiple time execution to see increase in values. :)
- Check actual datapath utilization at that instance: "show platform hardware qfp active datapath utilization summary" CLI.
- Check if there is any issue with NAT translations, NAT drops, etc using NAT CLIs.
I don't see any static NAT in the configuration. Either way, the default route looks wrong. If this is your outside interface:
ip nat outside
negotiation auto
then the default route should be
ip route 0.0.0.0 0.0.0.0 37.2.15.78
and not
Also, remove the default gateway:
--> no ip default-gateway 37.2.15.78
