4500X PBR problem on SVIs
jnesbitt1
I have been trying to get PBR to work on a 4500x running entservices for the last few days in my lab before deploying into production. However, I am having problems getting PBR to work on the SVIs; local PBR is working as desired on the core. I did however get PBR to function properly on a 3750x running ipservcies. Below is the general setup:
I just noticed the subnet on the firewall for V405 and V405 on the core are marked as different subnets. I verified this in the config and both are /29. I just mismarked the diagram. (9-19-2018)
Vlan 400: MGT Plane for all switches
Vlan 405: L3 Interconnect between core and firewall
Vlan 150: User subnet 10.10.150.0 /24
Vlan 160: User subnet 10.10.160.0 /24
Desired traffic flow:
All traffic coming from any user IP address directed to a switch IP on vlan 400 needs to go through the firewall first. In addition, all traffic originated on vlan 400 such as syslog, ping and ntp need to go through the firewall; this part functions properly as the local PBR route-map on the core directs traffic from the core's vlan 400 to the firewall. Additionally the access layer switches direct their traffic to their default gateway of 192.168.30.1 (Firewall sub-interface).
Here is the PBR configuration that worked as intended on a 3750x but not a 4500x:
access-list 130 permit ip any 192.168.30.0 0.0.0.255
access-list 135 permit ip 192.168.30.0 0.0.0.255 any
route-map pcnm permit 300
match ip address 130
set ip next-hop 192.168.35.1
exit
route-map local permit 300
match ip address 135
set ip next-hop 192.168.30.1
exit
interface vlan 150
ip policy route-map pcnm
exit
interface vlan 160
exit
ip local policy route-map local
When issuing a show route-map I see matches on both policies. To help troubleshoot I issued a 'debug ip policy' on the core and received the following results:
Test1:
Ping from PBR-Core to PC#1: Traffic is routed through the firewall as expected
*Aug 30 15:52:41.361 MST: IP: s=192.168.30.2 (local), d=10.10.150.5, len 100, policy match route map local, item 300, permit
*Aug 30 15:52:41.361 MST: IP: s=192.168.30.2 (local), d=10.10.150.5 (Vlan400), len 100, policy routed local to Vlan400 192.168.30.1
*Aug 30 15:52:41.364 MST: IP: s=192.168.30.2 (local), d=10.10.150.5, len 100, policy match route map local, item 300, permit
Test2:
Ping from PC#1 to PBR-Core: Traffic is routed laterally and does not go through firewall; however PBR-Core sends ICMP reply back through firewall which is expected. What is not seen is a policy match for PC#1 (10.10.150.5) to PBR-Core (192.168.30.2). This traffic is defined in access list 130 but for some reason the inbound traffic on interface 150 does not check against the route-map.
*Aug 30 15:55:23.659 MST: IP: s=192.168.30.2 (local), d=10.10.150.5, len 60, policy match route map local, item 300, permit
*Aug 30 15:55:23.659 MST: IP: s=192.168.30.2 (local), d=10.10.150.5 (Vlan400), len 60, policy routed local to Vlan400 192.168.30.1
Test3:
Ping from PC#1 to Switch#1: No log appears on the PBR-Core showing inbound traffic against the route-map. However, the traffic is observed on the firewall and traffic to and from Switch#1 to PC#1 behave as desired.
What am I missing? My money is on one simple command that's needed on the 4500x. Thanks in advance.
21 Replies 21
Ok that makes sense.
Can you post the switch configs so we can see exactly what is setup.
Bear in mind with hardware switches that you do not always see hits on the acls so it is not always the best way to verify PBR.
Jon
Well I was hoping to find a way to attach this rather than paste it but I don't see a way. Here is the config for the switches:
Core Switch
no service pad
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service compress-config
hostname PBR-Core
boot-start-marker
boot system bootflash:/cat4500e-universalk9.SPA.03.08.06.E.152-4.E6.bin
boot-end-marker
vrf definition mgmtVrf
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
logging buffered 4096
enable secret 5 **********
username !admin secret 5 ****************
no aaa new-model
clock timezone MDT -7 0
clock summer-time MST recurring
switch virtual domain 10
 switch mode virtual
 switch 1 priority 150
 mac-address use-virtual
no ip source-route
no ip cef optimize neighbor resolution
ip domain-name pcn.local
vtp domain pcn.local
vtp mode transparent
power redundancy-mode redundant
mac access-list extended VSL-BPDU
 permit any 0180.c200.0000 0000.0000.0003
mac access-list extended VSL-CDP
 permit any host 0100.0ccc.cccc
mac access-list extended VSL-DOT1x
 permit any any 0x888E
mac access-list extended VSL-GARP
 permit any host 0180.c200.0020
mac access-list extended VSL-LLDP
 permit any host 0180.c200.000e
mac access-list extended VSL-MGMT
 permit any 0022.bdcd.d200 0000.0000.00ff
 permit 0022.bdcd.d200 0000.0000.00ff any
mac access-list extended VSL-SSTP
 permit any host 0100.0ccc.cccd
archive
 log config
  logging enable
  logging size 200
  notify syslog contenttype plaintext
  hidekeys
spanning-tree mode rapid-pvst
spanning-tree portfast edge default
spanning-tree portfast edge bpduguard default
redundancy
 mode sso
vlan internal allocation policy ascending
vlan 150
 name V150
vlan 160
 name V160
vlan 400
 name V400
vlan 405
 name V405
vlan 888
 name HONEYPOT
vlan 931
 name NATIVE
class-map match-any VSL-MGMT-PACKETS
 match access-group name VSL-MGMT
class-map match-any VSL-DATA-PACKETS
 match any
class-map match-any VSL-L2-CONTROL-PACKETS
 match access-group name VSL-DOT1x
 match access-group name VSL-BPDU
 match access-group name VSL-CDP
 match access-group name VSL-LLDP
 match access-group name VSL-SSTP
 match access-group name VSL-GARP
class-map match-any VSL-L3-CONTROL-PACKETS
 match access-group name VSL-IPV4-ROUTING
 match access-group name VSL-BFD
 match access-group name VSL-DHCP-CLIENT-TO-SERVER
 match access-group name VSL-DHCP-SERVER-TO-CLIENT
 match access-group name VSL-DHCP-SERVER-TO-SERVER
 match access-group name VSL-IPV6-ROUTING
class-map match-any VSL-MULTIMEDIA-TRAFFIC
 match dscp af41
 match dscp af42
 match dscp af43
 match dscp af31
 match dscp af32
 match dscp af33
 match dscp af21
 match dscp af22
 match dscp af23
class-map match-any VSL-VOICE-VIDEO-TRAFFIC
 match dscp ef
 match dscp cs4
 match dscp cs5
class-map match-any VSL-SIGNALING-NETWORK-MGMT
 match dscp cs2
 match dscp cs3
 match dscp cs6
 match dscp cs7
policy-map VSL-Queuing-Policy
 class VSL-MGMT-PACKETS
  bandwidth percent 5
 class VSL-L2-CONTROL-PACKETS
  bandwidth percent 5
 class VSL-L3-CONTROL-PACKETS
  bandwidth percent 5
 class VSL-VOICE-VIDEO-TRAFFIC
  bandwidth percent 30
 class VSL-SIGNALING-NETWORK-MGMT
  bandwidth percent 10
 class VSL-MULTIMEDIA-TRAFFIC
  bandwidth percent 20
 class VSL-DATA-PACKETS
 class class-default
  bandwidth percent 5
interface Port-channel1
 description "VSL Link from Switch 1"
 switchport
 switchport mode trunk
 switchport nonegotiate
 switch virtual link 1
interface Port-channel2
 description "VSL Link from Switch 2"
 switchport
 switch virtual link 2
interface TenGigabitEthernet1/1/1
 description "Link to SW1"
 switchport access vlan 888
 switchport trunk allowed vlan 150,300,400
 switchport trunk native vlan 931
interface TenGigabitEthernet1/1/2
 description "Link to Sw2"
 switchport trunk allowed vlan 160,300,400
interface TenGigabitEthernet1/1/3
 description "Link to FW"
interface TenGigabitEthernet1/1/29
 description ***VSL Link - Port-channel 1***
 no lldp transmit
 no lldp receive
 no cdp enable
 channel-group 1 mode on
 service-policy output VSL-Queuing-Policy
interface TenGigabitEthernet1/1/30
 description "Dual-Active Detection"
 dual-active fast-hello
interface TenGigabitEthernet1/1/31
 no lldp transmit
 no lldp receive
 no cdp enable
interface TenGigabitEthernet1/1/32
interface TenGigabitEthernet2/1/29
 description ***VSL Link - Port-channel 2***
 no lldp transmit
 no lldp receive
 no cdp enable
 channel-group 2 mode on
interface TenGigabitEthernet2/1/30
interface TenGigabitEthernet2/1/31
 no lldp transmit
 no lldp receive
 no cdp enable
interface TenGigabitEthernet2/1/32
interface Vlan1
 no ip address
interface Vlan150
 ip address 10.10.150.1 255.255.255.0
interface Vlan160
 ip address 10.10.160.1 255.255.255.0
interface Vlan400
 ip address 192.168.30.2 255.255.255.0
interface Vlan405
 ip address 192.168.35.2 255.255.255.248
ip default-gateway 192.168.30.1
no ip forward-protocol nd
no ip forward-protocol udp tftp
no ip forward-protocol udp nameserver
no ip forward-protocol udp domain
no ip forward-protocol udp time
no ip forward-protocol udp netbios-ns
no ip forward-protocol udp netbios-dgm
no ip forward-protocol udp tacacs
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.35.1
ip ssh time-out 10
ip access-list extended VSL-BFD
 permit udp any any eq 3784
ip access-list extended VSL-DHCP-CLIENT-TO-SERVER
 permit udp any eq bootpc any eq bootps
ip access-list extended VSL-DHCP-SERVER-TO-CLIENT
 permit udp any eq bootps any eq bootpc
ip access-list extended VSL-DHCP-SERVER-TO-SERVER
 permit udp any eq bootps any eq bootps
ip access-list extended VSL-IPV4-ROUTING
 permit ip any 224.0.0.0 0.0.0.255
ip sla enable reaction-alerts
logging trap notifications
logging source-interface Vlan300
logging host ***
logging host ***
access-list * remark "SNMP RO Access"
access-list * permit *
access-list * deny   any log
access-list * remark "VTY Access List"
access-list * remark "NTP Server Access List"
access-list 115 permit ip 10.10.150.0 0.0.0.255 192.168.30.0 0.0.0.255
 match ip address 115 130
ipv6 access-list VSL-IPV6-ROUTING
 permit ipv6 any FF02::/124
no vstack
line con 0
 session-timeout 10
 timeout login response 15
 logging synchronous
 transport preferred none
 stopbits 1
line vty 0 4
 session-timeout 10
 access-class * in
 logging synchronous
 login
 transport input ssh
line vty 5 15
 session-timeout 10
 access-class * in
 logging synchronous
 login
 transport input ssh
module provision switch 1
 chassis-type 72 base-mac 006B.F156.9A00
 slot 1 slot-type 402 base-mac 006B.F156.9A00
module provision switch 2
 chassis-type 72 base-mac B838.6121.D748
 slot 1 slot-type 402 base-mac B838.6121.D748
 slot 2 slot-type 400 base-mac 4C4E.358C.F858
 ntp access-group peer *
 ntp server *
 ntp server * prefer
end
PBR-Core#
Switch #1 (Switch 2 is configured the same expect for IP and name)
no service pad
hostname Switch-1
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
switch 1 provision ws-c2960x-24td-l
no ip source-route
vtp domain PCN.LOCAL
archive
 log config
  logging enable
  logging size 200
  hidekeys
vlan 150
 name V150
vlan 400
 name V400
vlan 888
 name HONEYPOT
vlan 931
 name NATIVE
interface FastEthernet0
 no ip address
interface GigabitEthernet1/0/1
 switchport access vlan 121
 switchport mode access
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
 description "V150 Access"
 switchport access vlan 150
interface GigabitEthernet1/0/26
 switchport trunk allowed vlan 150,400
interface TenGigabitEthernet1/0/1
interface TenGigabitEthernet1/0/2
interface Vlan1
 no ip address
 shutdown
interface Vlan400
 ip address 192.168.30.3 255.255.255.0
no ip http server
ip ssh time-out 10
ip ssh source-interface Vlan400
logging source-interface Vlan400
logging host *
logging host *
no vstack
line con 0
line vty 5 15
end
Switch-1#
Here is a screen capture of a ping test from PC#1 to Switch #1 and Switch #2 according to the firewall logs (Image 1). As you can see the source information and destinations are in the correct order along with the application. There was no output from the Core when I used the 'debug ip policy' command.
(Image 1)
Next is a ping test from PC#1 to the Core switch (Image 2 & 3). With this test I got hits on the Core using the 'debug ip policy' but only for the return traffic from the Core to PC#1. Notice the firewall log source and destination zones are backwards along with the incorrect application. To me shows that the ping from PC#1 to the core is going laterally rather than going through the firewall as desired.
(Image 2)
(Image 3)
Bumping. I'm about to deploy another network with the similar architecture and need to get this problem figured out. I do remember that on the 3750X I had to modify the SDM template but was unable to find the same commands on the 4500X. Is there a way to modify the template?
can you share the output of the following command show sdm prefer
Doesn't look like that command is available on the 4500X.
-Jon
Bumping in the hopes we can find a solution.
