06-29-2009 01:51 PM - edited 03-04-2019 05:16 AM
We are planning the installation of a ATM IMA bundle of 6 x E1 in a Cisco3845 router. Due to the network module NM-8E1-IMA is EOL/EOS, Can I install two AIM-ATM-4T1= in order to build a 6 x E1s IMA Bundle?
Solved! Go to Solution.
06-30-2009 04:35 AM
No. It is not possible to have more than 4 circuits in IMA group on an ISR router.
The best you can do, is two groups with three circuits each, and CEF loadbalance the L3 interface.
06-30-2009 04:35 AM
06-30-2009 02:36 PM
Thanks, that is a good solution.
