6500 Redundancy Question
John Apricena
I have a question with regards to 6500 Redundancy. We currently have only one in our DC, it has 2 SUP 720s, two FWSMS, and multiple switchport blades. My question is is this fully redundant? and if not what is it that can fail, so I can look into adding that extra layer of redundancy. Any advice would be greatly appreciated. Thank You!
2 Accepted Solutions
Edison Ortiz
No, you have a single point of failure. If you lose the chassis, no matter how many supervisors you have - you have an outage. I recommend getting another chassis with similar modules and dual-home every single device.
Edison
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
Just wanted to expand on Edison's post, if you go the dual homed approach, "similar" doesn't have to mean identical.  Much depends on whether fail over has to offer same performance as before failure.
Also, with dual chassis, you might be able to migrate your 2nd sup to 2nd chassis and save some $.
Edison Ortiz
Edison
Thanks for the info guys very helpful!
Joseph W. Doherty
Disclaimer
Posting
