Point-to-Point Serial link Up-Down
newnetman
May i anseek urgent help from anyone with idea as to what the problem might be with the following configuration on a P-2-P serial link going up and down?.
ROUTER-A
interface Serial1/2
ip address 10.1.1.1 255.0.0.0
encapsulation frame-relay
end
ROUTER-B
interface Serial1/2
ip address 10.1.1.2 255.0.0.0
clock rate 72000
end
Thanks for the help in advance
bagvanliju
Hai,
1)Try to change the encapsulation to HDLC and perform a end to end loop testing to verify Physical media is tru...once is done ..will come to know were could be the issue...
2)check out put of both interface any crc erros/reliablity/interface reset ....
3)Is this a lab senario or live setup ...cz u are using /8 as subnet mask ....
let us know the status
ujil
