7200 to ASR migration - configurations not taking
edchow1980
Migrating some configurations from a 7200 to an ASR, although it appears the following commands are not present.
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 15.1(3)S2, RELEASE SOFTWARE (fc1)
Any ideas on what commands may have replaced these or if I am missing something here?
interface Serial0/2/0:0
dialer rotary-group 1
dialer-group 1
isdn switch-type primary-net5
interface Serial0/2/1:0
dialer-group 1
paolo bevilacqua
Are you trying to use ASR for ISDN? That doesn not seem the best application for a multi-gigabit router.
It is required in the interim to support existing legacy infrastructure.
Hello Edward,
I believe ISDN PRI is not supported on ASR1K. A limited ISDN functionality has been ported to 15.3(1)S throttle, so I would suggest you to upgrade the IOS and verify the behavior.
Please, take a look at feature guide below:
http://www.cisco.com/en/US/docs/ios-xml/ios/vpdn/configuration/xe-3s/asr1000/vpd-isdn-access-bba.html
Best regards,
Dmitry Skotnikov
-- Best regards, Dmitry Skotnikov
Thanks Dmytro, I will look into this.
