7606-s 10 Giga interfaces
mohameddz
Hello every one;
at my company we have a 7606-s router and we want to get a card with some 10Giga port using SFP+
can any one help choosing please ?
RTR#sh module
Mod Ports Card Type Model Serial No.
1 0 4-subslot SPA Interface Processor-400 7600-SIP-400 JAB103400Y1
2 0 4-subslot SPA Interface Processor-400 7600-SIP-400 JAB1034046Z
3 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL09148EJ4
4 20 7600 ES+ 7600-ES+20G3CXL JAE1340KH0U
5 2 Route Switch Processor 720 (Active) RSP720-3CXL-GE JAE1405388I
6 2 Route Switch Processor 720 (Hot) RSP720-3CXL-GE SAL16052QWF
RTR#sh version
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 15.5(3)S5, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2017 by Cisco Systems, Inc.
Compiled Wed 18-Jan-17 06:12 by prod_rel_team
ROM: System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 15.5(3)S5, RELEASE SOFTWARE (fc1)
core1-ca1.alg.icosnet.net uptime is 11 weeks, 4 days, 1 hour, 47 minutes
Uptime for this control processor is 11 weeks, 4 days, 1 hour, 40 minutes
System returned to ROM by reload (SP by reload)
System restarted at 14:47:50 ALG Wed Nov 22 2017
System image file is "sup-bootdisk:c7600rsp72043-adventerprisek9-mz.155-3.S5.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO7606-S (M8500) processor (revision 2.0) with 3670016K/262144K bytes of memory.
Processor board ID FXS1802Q07A
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.0, (0x80390020)
CORE: E500, Version: 2.0, (0x80210020)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1: D-cache 32 kB enabled
I-cache 32 kB enabled
Last reset from power-on
2 SIP-400 controllers (13 POS)(1 Channelized OC12/STM-4).
1 Virtual Ethernet interface
48 Gigabit Ethernet interfaces
13 Packet over SONET interfaces
1 Channelized OC12 interface
3964K bytes of non-volatile configuration memory.
507024K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
Reza Sharifi
There is (WS-X6704-10GE). This module supports XenPac optics which is SC-type connector and not LC.
So, it does not support SFP+.
see figure-2-31 in this link
https://www.cisco.com/c/en/us/td/docs/routers/7600/Hardware/Hardware_Guides/7600_Series_Router_Module_Guide/modguid/02ethern.html#wp1042590
thanks reza
the "WS-X6704-10GE" seem to be an old card, we are lookin for somthing recent and supporting SFP+ modules.
is ther any other card with 10 Giga port for 7606-s ?
thanks.
