Limiting bandwidth again [ISR 886VA]
Exonix
good day,
i'm trying to configure Speed Limit on Cisco router ISR 886VA. I have read this article, and understood that i have to use polices instead of shaping because in need limit incoming speed for a host. That i'm doing:
access-list 102 permit ip any host 10.254.1.4
class-map match-all Mikrotik-Dev
 match access-group 102
policy-map Hosts
 class Mikrotik-Dev
  bandwidth 35000
But when I link this policy on WAN interface I get an error:
(config)#interface ethernet 0
(config-if)#service-policy input Hosts
Bandwidth command not allowed at parent level in input direction
How can I limit the incoming speed for a host?
Thank you!
Exonix
also, i have configured it like that, but it does not limit the speed...
policy-map Hosts
 class Mikrotik-Dev
  police cir 35000000
   conform-action transmit
interface Ethernet0
 description WAN
 no ip address
 ip nbar protocol-discovery ipv4
or:
interface Vlan1
 description LAN
 ip address 10.254.1.1 255.255.255.0
 ip flow ingress
 ip nat inside
 ip virtual-reassembly in
