7606-S Boots to Rommon
ehawks001
I've been struggling to resolve a booting issue with our lab 7606-s with a single sup720-3bxl installed. This unit was configured and stayed powered down for severla months. A couple weeks ago I powered it up to do some development work and the router would only boot to Rommon. Here's the message I received:
System Bootstrap, Version 8.1(3)
Copyright (c) 1994-2004 by cisco Systems, Inc.
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower 16K memory for cache initialization
Clearing bss
Clearing autoboot state machine
Reading monitor variables from NVRAM
Reset reason 0xffff.
Enabling interrupts
Initializing TLB
Initializing cache
Initializing required TLB entries
Initializing main memory
Sizing NVRAM
Initializing PCMCIA controller
Exiting init
Cat6k-Sup720/SP processor with 1048576 Kbytes of main memory
Autoboot executing command: "boot "
Read cis from dev 1 error (-6)device does not contain a valid magic number
boot: cannot open "bootflash:"
boot: cannot determine first file name on device "bootflash:"
I was unable to view the contents of bootflash: in rommon, same magic number error. I inserted a formated card with an IOS image into the front Disk0: slot and was able to boot IOS off that. Within IOS cli I was able to view bootflash: directory and files and confirm my boot image was still present.
Now upon boot I cannot even get to rommon. Here's what the boot process currently looks like from power-on:
Clearing bss
Enabling interrupts
Initializing TLB
Initializing cache
Sizing NVRAM
Exiting init
Clearing bss
Enabling interrupts
Initializing TLB
Initializing cache
Sizing NVRAM
Exiting init
*** Address Error (Load/Fetch) Exception ***
Access address = 0x542b6c7f
PC = 0x542b6c7f, Cause = 0x10, Status Reg = 0x30409003
ROM Monitor Can Not Recover From Exception
A Board Reset Is Issued
This "address error" repeats over and over again. I'm not sure if all of this is indicative of a hardware failure or if I'm overlooking a troubleshooting step.
yahsiel2004
Level 7
Level 7
Have you tried booting up without the flashcard inserted? If you haven'y try it and see if you get into rommon. If you do, then put the flashcard back and boot off the card. Then once booted up try to format the bootflash and copy a IOS image to it.
Yosh
HTH Regards, Yosh
Thanks for the suggestion. I neglected to mention that I have previously formated bootflash: and the sup-bootdisk: in an effort to resume normal auto boot.
I believe my problem was centered around rommon not being able to read bootflash:, but even after formatting that the problem persisted. What I'm most concerned about now is the *** Address Error (Load/Fetch) Exception ***
that scrolls and scrolls and I cannot get back to rommon.
Ehren,
This is probably a hardware issue. Check the link below:
https://supportforums.cisco.com/docs/DOC-2721
Yosh
HTH Regards, Yosh
This is what I was afraid of, but expecting. Thanks for your input.
