re-marking DSCP values
lcaruso
Level 6
Level 6
Is there a mechanism to re-mark from DSCP values to other DSCP values on a router?
I'm supposed to match on a number of DSCP values in a class-map.
Then some of the DSCP values get re-mapped to one value while others get remapped to another value.
I've tried table-map but that only maps from DSCP to COS and visa versa. I want to map from DSCP to DSCP.
Many to Many mappings.
Thanks.
2 Accepted Solutions
yahsiel2004
Level 7
Level 7
Yea it's called DSCP mutation.
mls qos map dscp-mutation
To define a named differentiated services code point (DSCP) mutation map, use the mls qos map dscp-mutation command in global configuration mode. To return to the default mapping, use the no form of this command.
mls qos map dscp-mutation map-name input-dscp1 [input-dscp2 [input-dscp3 [input-dscp4 [input-dscp5 [input-dscp6 [input-dscp7 [input-dscp8]]]]]]] to output-dscp
no mls qos map dscp-mutation map-name
Syntax Description
map-name
Name of the DSCP mutation map.
input-dscp#
Internal DSCP value; valid values are from 0 to 63. See the "Usage Guidelines" section for additional information.
to
Defines mapping.
output-dscp
Egress DSCP value; valid values are from 0 to 63.
Command Default
output-dscp equals input-dscp.
Command Modes
Global configuration
Command History
Release
Modification
12.3(4)T
This command was integrated into Cisco IOS Release 12.3(4)T on the  following platforms: Cisco 2600 series, Cisco 3600 series, and  Cisco 3700 series routers.
12.2(14)SX
Support for this command was introduced on the Supervisor Engine 720.
12.2(33)SRA
This command was integrated into Cisco IOS Release 12.2(33)SRA.
Usage Guidelines
This command is not supported on the Catalyst 6500 series switches and  the Cisco 7600 series routers that are configured with a Supervisor  Engine 2.
When configuring a named DSCP mutation map, note the following:
You can enter up to eight input DSCP values that map to a mutated DSCP value.
You can enter multiple commands to map additional DSCP values to a mutated DSCP value.
You can enter a separate command for each mutated DSCP value.
You can configure 15 egress-DSCP mutation maps to mutate the internal  DSCP value before it is written as the egress-DSCP value. You can attach  egress-DSCP mutation maps to any interface that Policy Feature Card  (PFC) QoS supports.
PFC QoS derives the egress-class-of-service (CoS) value from the  internal DSCP value. If you configure egress-DSCP mutation, PFC QoS does  not derive the egress-CoS value from the mutated DSCP value.
Examples
This example shows how to map DSCP 30 to mutated DSCP value 8:
Router(config)# mls qos map dscp-mutation mutemap1 30 to 8
Yosh
HTH Regards, Yosh
Hello
from a switch perspective
mls qos map dscp-mutation DSCPChanges 8 to 10
mls qos map dscp-mutation DSCPChanges 9 11 13 14 15 to 12
mls qos map dscp-mutation DSCPChanges 16 to 18
mls qos map dscp-mutation DSCPChanges 17 19 21 22 23 to 20
mls qos map dscp-mutation DSCPChanges 24 to 26
mls qos map dscp-mutation DSCPChanges 25 27 29 30 31 to 28
mls qos map dscp-mutation DSCPChanges 32 33 35 36 37 38 39 to 34
int xxx
mls qos dscp-mutation DSCPChanges
mls qos trust dscp
sh mls qos maps dscp-mutation
   Dscp-dscp mutation map:
  DSCPChanges:
     d1 :  d2 0  1  2  3  4  5  6  7  8  9
      0 :    00 01 02 03 04 05 06 07 10 12
      1 :    10 12 12 12 12 12 18 20 18 20
      2 :    20 20 20 20 26 28 26 28 28 28
      3 :    28 28 34 34 34 34 34 34 34 34
      4 :    40 41 42 43 44 45 46 47 48 49
      5 :    50 51 52 53 54 55 56 57 58 59
      6 :    60 61 62 63
   Default DSCP Mutation Map:
      0 :    00 01 02 03 04 05 06 07 08 09
      1 :    10 11 12 13 14 15 16 17 18 19
      2 :    20 21 22 23 24 25 26 27 28 29
      3 :    30 31 32 33 34 35 36 37 38 39
      6 :    60 61 62 63
From a router perspective ( even thought the router is taking this config not sure if this is all that applicabledue to the dscp -cos vaule values of 0,8,16 etc.) so
dscp 0-8 - dscp of 0
dscp 8 -15 dscp =1
dscp 16-23 dscp= 2
etc
etc...
class-map match-all Dscp8
match  dscp cs1
class-map match-all Dscp9-11-13-14-14
match  dscp 9  11  13  af13  15
class-map match-all Dscp24
match  dscp cs3
class-map match-all Dscp16
match  dscp cs2
class-map match-all Dscp17-19-21-22-23
match  dscp 17  19  21  af23  23
class-map match-all Dscp25-27-29-30-31
match  dscp 25  27  29  af33  31
class-map match-all Dscp32-33-35to39
match  dscp cs4  33  35  af42  37  af43  39
policy-map DSCP_pm
class Dscp8
  set dscp af11
class Dscp9-11-13-14-14
  set dscp af12
class Dscp24
  set dscp af31
class Dscp16
  set dscp af21
class Dscp17-19-21-22-23
  set dscp af22
class Dscp25-27-29-30-31
  set dscp af32
class Dscp32-33-35to39
  set dscp af41
int xx
service-policy xxput DSCP_pm
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
8 Replies 8
lcaruso
Level 6
Level 6
This is an example of both what I need and tried.
table-map COS2-MAP
map from  24 to 26
map from  25 to 28
map from  26 to 26
map from  27 to 28
map from  28 to 28
map from  29 to 28
map from  30 to 28
map from  31 to 28
default copy
class-map match-any COS2
match dscp cs3  25  af31  27  af32  29  af33  31
policy-map FOO
class COS2
  bandwidth remaining percent 30 account user-defined 24
  set dscp cos table COS2-MAP
  queue-limit 64 packets
  fair-queue
  random-detect dscp-based
This is what I need to accomplish...just taking one class an example here.
    Class                    COS2
    TOS Byte                 011xxxYY
    DHCP PHB                 CS3, AF3x
    Compliant DSCP values    24(cs3), 26(af31)
    Noncompliant DSCP values 25, 27, 28(af32), 29, 30(af33), 31
    CE Compliant Action      Remark to 26(af31)
    CE noncompliant Action   Remark to 28(af32)
    PE Compliant Action      Map to EXP-4
    PE Noncompliant Action   Map to EXP-3
I don't think you can use table-map to change DSCP to DSCP(as far as I know) if this is what you want
You would have to use 1 table-map from DSCP to Qos-group and 1 table-map from QoS-group to DSCP( for example).
Otherwise you can use just regular MQC matching on DSCP and resetting DSCP
Alain
lcaruso
Level 6
Level 6
Thanks for your reply. I haven't found an example of a many to many dscp mapping just many to one. Can you provide an example?
Sent from Cisco Technical Support Android App
many to many with classical MQC is not possible as far as I know.
Alain
yahsiel2004
Level 7
Level 7
Syntax Description
map-name
input-dscp#
to
Defines mapping.
output-dscp
Command Default
Command Modes
Command History
Release
Modification
12.3(4)T
12.2(14)SX
12.2(33)SRA
Usage Guidelines
Examples
Yosh
HTH Regards, Yosh
Hi thanks for your suggestion. It only works on switches.
router(config)#mls qos map dscp-mutation mutemap1 30 to 8
% Invalid input detected at '^' marker.
router(config)#mls qos map ?
  cos-dscp  cos-dscp map: eight dscp values for cos 0-7
  dscp-cos  dscp-cos map: up to thirteen dscp values
I was trying to find a solution on the router. It seems like I'll need to write a bunch of individual class maps and policies to affect these transformations and put them on the ingress port. I was hoping to find a better way than this.
There are the DSCP to DSCP mappings I need to perform. Thats a lot of class maps and policys.
map from  24 to 26
map from  25 to 28
map from  26 to 26
map from  27 to 28
map from  28 to 28
map from  29 to 28
map from  30 to 28
map from  31 to 28
map from  32 to 34
map from  33 to 34
map from  34 to 34
map from  35 to 34
map from  36 to 34
map from  37 to 34
map from  38 to 34
map from  39 to 34
map from  16 to 18
map from  17 to 20
map from  18 to 18
map from  19 to 20
map from  20 to 20
map from  21 to 20
map from  22 to 20
map from  23 to 20
map from  8 to 10
map from  9 to 12
map from  10 to 10
map from  11 to 12
map from  12 to 12
map from  13 to 12
map from  14 to 12
map from  15 to 12
Hello
int xxx
mls qos trust dscp
  DSCPChanges:
      6 :    60 61 62 63
      6 :    60 61 62 63
dscp 8 -15 dscp =1
dscp 16-23 dscp= 2
etc
etc...
match  dscp cs1
match  dscp cs3
match  dscp cs2
policy-map DSCP_pm
class Dscp8
  set dscp af11
  set dscp af12
class Dscp24
  set dscp af31
class Dscp16
  set dscp af21
  set dscp af22
  set dscp af32
  set dscp af41
int xx
res
Paul
Thanks.
Kind Regards
Paul
Thank you!
