7609 restart it's SFP linecard every day
Hi all!
Can you help to determine the resone of failure?
Here is the the log:
Dec 19 15:16:11: %MFIB_PLTF-DFC3-3-TABLE_HANDLE_BAD: Range. 0x0 -Process= "mfib-const-lc Process", ipl= 0, pid= 211
-Traceback= 20B5F344 20B5B020 20C0A90C 20BECD28 20BCC75C 20BCE494 20BC1868 20BC1FE8 20B1DA9C 20BC20B4 20BDD364 20BCDD24 20BF9ED4
Dec 19 15:22:39: %MFIB_PLTF-DFC3-3-ENTRY_HANDLE_BAD: Range. 0x0 -Process= "mfib-const-lc Process", ipl= 0, pid= 211
-Traceback= 20B5F4CC 20B5B3F4 20C0A520 20BECD14 20BCC75C 20BCE494 20BC1868 20BC1FE8 20B1DA9C 20BC20B4 20BDD364 20BCDD24 20BF9ED4
Dec 19 15:22:39: %MFIB_PLTF-DFC3-3-TABLE_HANDLE_BAD: Range. 0x0 -Process= "mfib-const-lc Process", ipl= 0, pid= 211
Dec 19 15:22:53: %MFIB_PLTF-DFC3-3-ENTRY_HANDLE_BAD: Range. 0x0 -Process= "mfib-const-lc Process", ipl= 0, pid= 211
Dec 19 15:22:53: %MFIB_PLTF-DFC3-3-TABLE_HANDLE_BAD: Range. 0x0 -Process= "mfib-const-lc Process", ipl= 0, pid= 211
Dec 19 15:23:09: %MFIB_PLTF-DFC3-3-ENTRY_HANDLE_BAD: Range. 0x0 -Process= "mfib-const-lc Process", ipl= 0, pid= 211
Dec 19 15:23:09: %MFIB_PLTF-DFC3-3-TABLE_HANDLE_BAD: Range. 0x0 -Process= "mfib-const-lc Process", ipl= 0, pid= 211
Dec 19 15:23:31: %MFIB_PLTF-DFC3-3-ENTRY_HANDLE_BAD: Space. 0x20BE3FAC -Process= "XDR mcast", ipl= 0, pid= 217
-Traceback= 20B5F4CC 20B5AFCC 20C0AB34 20BE9398 20BEA534 20BE924C 2165192C 21650FCC
Dec 19 15:23:34: %MFIB_PLTF-DFC3-3-TABLE_HANDLE_BAD: Range. 0x0 -Process= "mfib-const-lc Process", ipl= 0, pid= 211
Dec 19 15:24:08: %CPU_MONITOR-SP-6-NOT_HEARD: CPU_MONITOR messages have not been heard for 31 seconds [3/0]
Dec 19 15:24:38: %CPU_MONITOR-SP-6-NOT_HEARD: CPU_MONITOR messages have not been heard for 61 seconds [3/0]
Dec 19 15:25:08: %CPU_MONITOR-SP-6-NOT_HEARD: CPU_MONITOR messages have not been heard for 91 seconds [3/0]
Dec 19 15:25:24: %XDR-6-XDRIPCNOTIFY: Message not sent to slot 3/0 (3) because of IPC error timeout. Disabling linecard. (Expected during linecard OIR)
Dec 19 15:25:38: %CPU_MONITOR-SP-6-NOT_HEARD: CPU_MONITOR messages have not been heard for 121 seconds [3/0]
Dec 19 15:26:08: %CPU_MONITOR-SP-6-NOT_HEARD: CPU_MONITOR messages have not been heard for 151 seconds [3/0]
Dec 19 15:26:39: %PIM-5-NBRCHG: neighbor 172.16.3.9 DOWN on interface Vlan129 non DR
Dec 19 15:26:39: %PIM-5-NBRCHG: neighbor 172.16.3.18 DOWN on interface Vlan397 DR
Dec 19 15:26:38: %CPU_MONITOR-SP-3-TIMED_OUT: CPU_MONITOR messages have failed, resetting module [3/0]
Dec 19 15:26:38: %OIR-SP-3-PWRCYCLE: Card in module 3, is being power-cycled off (Heartbeat Messages Not Received From Module)
Dec 19 15:26:39: %C7600_PWR-SP-4-DISABLED: power to module in slot 3 set off (Heartbeat Messages Not Received From Module)
Dec 19 15:26:44: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.4.2 on Vlan22 from FULL to DOWN, Neighbor Down: Interface down or detached
Dec 19 15:26:44: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.4.3 on Vlan22 from FULL to DOWN, Neighbor Down: Interface down or detached
Dec 19 15:26:44: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.4.4 on Vlan22 from FULL to DOWN, Neighbor Down: Interface down or detached
Dec 19 15:26:44: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.4.5 on Vlan22 from FULL to DOWN, Neighbor Down: Interface down or detached
Dec 19 15:26:44: %OSPF-5-ADJCHG: Process 1, Nbr 172.16.4.30 on Vlan22 from FULL to DOWN, Neighbor Down: Interface down or detached
Dec 19 15:27:03: %IPMCAST_RPF-4-RPF_LOOKUP_LOOP: RPF route lookup loop for 10.6.15.135
Dec 19 15:27:07: %BGP-5-ADJCHANGE: neighbor 83.229.132.217 Down Interface flap
Dec 19 15:27:07: %BGP_SESSION-5-ADJCHANGE: neighbor 83.229.132.217 IPv4 Unicast topology base removed from session  Interface flap
Dec 19 15:27:37: %BGP-5-ADJCHANGE: neighbor 83.229.193.41 Down Interface flap
Dec 19 15:27:37: %BGP_SESSION-5-ADJCHANGE: neighbor 83.229.193.41 IPv4 Unicast topology base removed from session  Interface flap
*Mar  1 00:00:02.191: BaseBoard Index:152
*Mar  1 00:00:02.763: DaughterBoard Index:221 (Distributed Forwarding Card 3)
Firmware compiled 30-Apr-10 19:08 by integ Build [100]
Dec 19 12:28:30.256: %SYS-DFC3-5-RESTART: System restarted --
Cisco IOS Software, c6lc2 Software (c6lc2-SP-M), Version 12.2(33)SRE2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 05-Aug-10 20:01 by prod_rel_team
Dec 19 12:28:30.280: DFC3: Currently running ROMMON from S (Gold) region
Dec 19 15:28:39: %DIAG-SP-6-RUN_MINIMUM: Module 3: Running Minimal Diagnostics...
Dec 19 15:29:04: %DIAG-SP-6-DIAG_OK: Module 3: Passed Online Diagnostics
Dec 19 15:29:09: %OIR-SP-6-INSCARD: Card inserted in slot 3, interfaces are now online
Cisco7609#sh ver
Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRE2, RELEASE SOFTWARE (fc1)
ROM: System Bootstrap, Version 12.2(33r)SRD5, RELEASE SOFTWARE (fc1)
BOOTLDR: Cisco IOS Software, c7600rsp72043_rp Software (c7600rsp72043_rp-ADVENTERPRISEK9-M), Version 12.2(33)SRE2, RELEASE SOFTWARE (fc1)
Cisco7609 uptime is 4 days, 15 hours, 32 minutes
Uptime for this control processor is 4 days, 15 hours, 32 minutes
System returned to ROM by  power cycle (SP by power on)
System restarted at 13:09:48 MSK Wed Dec 15 2010
System image file is "bootdisk:c7600rsp72043-adventerprisek9-mz.122-33.SRE2.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
http://www.cisco.com/wwl/export/crypto/tool/stqrg.html you require further assistance please contact us by sending email to
export@cisco.com. CISCO7609-S (M8500) processor (revision 1.0) with 1900544K/131072K bytes of memory.
Processor board ID FOX1417GET5
BASEBOARD: RSP720
CPU: MPC8548_E, Version: 2.0, (0x80390020)
CORE: E500, Version: 2.0, (0x80210020)
CPU:1200MHz, CCB:400MHz, DDR:200MHz,
L1:    D-cache 32 kB enabled
        I-cache 32 kB enabled
If
Cisco
Last reset from power-on
85 Virtual Ethernet interfaces
98 Gigabit Ethernet interfaces
3964K bytes of non-volatile configuration memory.
507024K bytes of Internal ATA PCMCIA card (Sector size 512 bytes).
paolo bevilacqua
Update IOS.
If still trouble, contatct the TAC.
