861 configuration
skater2010
Hello:
I'm having problems getting a 861 router on line through a cable broadband connection with 1 static ip address.  I have been able to NAT the internal and external ip and get on line but I don't think that this is proper.  Another issue is that when the two interfacees are natted, I cannot access a web server on the lan, the incoming http requests are answered by the web server in the router.  Any help on this would be greatly apperciated!
Scott
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname cisco861
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
enable secret 5 $1$vwb3$TySirxZ.lm.YbMJNhhMQg1
no aaa new-model
memory-size iomem 10
clock timezone PCTime -6
clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00
crypto pki trustpoint TP-self-signed-3394879082
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3394879082
revocation-check none
rsakeypair TP-self-signed-3394879082
crypto pki certificate chain TP-self-signed-3394879082
certificate self-signed 01
  3082024F 308201B8 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33333934 38373930 3832301E 170D3036 30313032 31323030
  34335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 33393438
  37393038 3230819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100F2A0 4D17DD07 6C76F385 E6F456EE 141C0F91 CA7C1175 B176CB8C A273E17D
  511530C9 850FBDCC 67670E5F 54E05D4F A33A083E 42E819F8 F7B4FD22 3C2C2219
  0EF72883 2F767849 7950307A A74D8CFA D44E2D6B D625D237 0C8C8DAF FE8B331D
  50EB2945 0187BDDA A56F05D1 9AB8DB22 05DDC74D 889FC0F5 74F6571B 8F5B1013
  AE7B0203 010001A3 77307530 0F060355 1D130101 FF040530 030101FF 30220603
  551D1104 1B301982 17796F75 726E616D 652E796F 7572646F 6D61696E 2E636F6D
  301F0603 551D2304 18301680 14C27593 1F059686 3996F59E 93DBC11B 0E845AC9
  C8301D06 03551D0E 04160414 C275931F 05968639 96F59E93 DBC11B0E 845AC9C8
  300D0609 2A864886 F70D0101 04050003 818100DB 0FACA18D E9309BDD E742EA7A
  466B4562 945E8B25 9F5AAA74 2BE96A84 56547501 5D7FD1B6 618BFFCB 81001151
  3EFE5F89 0C752ECB 541885CD FCCF81E8 863BA75F 0F950D1A C8B631E9 1C77CA99
  7CA4C0B1 673DE637 4A953E58 0D11A85D 9CFC91B2 6DEF2E4E 527F1207 56B98BA6
  12E0F3CF 6CACE2C1 6CCCB16A 0CDDF155 E10A4A
  quit
no ip source-route
ip dhcp excluded-address 172.20.1.1 172.20.1.239
ip dhcp pool ccp-pool1
   import all
   network 172.20.1.0 255.255.255.0
   dns-server 65.24.0.168 4.2.2.2
   default-router 172.20.1.10
ip cef
no ip bootp server
ip name-server 65.24.0.168
ip name-server 4.2.2.2
license udi pid CISCO861-K9 sn FTX160784JB
username admin privilege 15 secret 5 $1$0TUG$bh270ROcyZGOINj0Ixisw/
ip tcp synwait-time 10
class-map type inspect match-any ccp-cls-insp-traffic
match protocol cuseeme
match protocol dns
match protocol ftp
match protocol h323
match protocol https
match protocol icmp
match protocol imap
match protocol pop3
match protocol shell
match protocol realmedia
match protocol rtsp
match protocol smtp
match protocol sql-net
match protocol streamworks
match protocol tftp
match protocol vdolive
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-insp-traffic
match class-map ccp-cls-insp-traffic
class-map type inspect match-any ccp-cls-icmp-access
match protocol icmp
match protocol tcp
match protocol udp
class-map type inspect match-all ccp-invalid-src
match access-group 100
class-map type inspect match-all ccp-icmp-access
match class-map ccp-cls-icmp-access
class-map type inspect match-all ccp-protocol-http
match protocol http
policy-map type inspect ccp-permit-icmpreply
class type inspect ccp-icmp-access
  inspect
class class-default
  pass
policy-map type inspect ccp-inspect
class type inspect ccp-invalid-src
  drop log
class type inspect ccp-protocol-http
  inspect
class type inspect ccp-insp-traffic
  inspect
class class-default
  drop
class class-default
  drop
zone security out-zone
zone security in-zone
zone-pair security ccp-zp-self-out source self destination out-zone
service-policy type inspect ccp-permit-icmpreply
zone-pair security ccp-zp-in-out source in-zone destination out-zone
service-policy type inspect ccp-inspect
zone-pair security ccp-zp-out-self source out-zone destination self
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description $FW_OUTSIDE$$ES_WAN$
ip address 24.106.44.210 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
zone-member security out-zone
duplex auto
speed auto
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$ES_LAN$$FW_INSIDE$
ip address 172.20.1.10 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
zone-member security in-zone
ip tcp adjust-mss 1452
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip route 0.0.0.0 0.0.0.0 24.106.44.209
logging trap debugging
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip host 255.255.255.255 any
access-list 100 permit ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip 24.106.44.208 0.0.0.3 any
no cdp run
control-plane
banner exec ^C
% Password expiration warning.
Cisco Configuration Professional (Cisco CP) is installed on this device
and it provides the default username "cisco" for  one-time use. If you have
already used the username "cisco" to login to the router and your IOS image
supports the "one-time" user option, then this username has already expired.
You will not be able to login to the router with this username after you exit
this session.
It is strongly suggested that you create a new username with a privilege level
of 15 using the following command.
username <myuser> privilege 15 secret 0 <mypassword>
Replace <myuser> and <mypassword> with the username and password you
want to use.
^C
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
scheduler allocate 4000 1000
scheduler interval 500
end
Richard Burts
Scott
Your description says that you were able to get address translation working to be able to get on line. But I do not see any evidence of that in the config that you posted. So there is not much that I can say about that other than to observe that it is a common solution to do nat overload when the router has a single public IP configured on the outside interface.
Do I understand correctly that you have a web server on your inside network that you want to be accessed from the Internet. To support that you generally need a static address translation. And that gets tricky when you only have a single public IP address. Usually when networks have servers inside that are accessed from the Internet they have negotiated with the ISP for more than one public address.
Rick
Rick
Hi Rick - I did remove NAT from this config thinking that I first needed to get connectivity through the default route alone.
Regarding the NAT situation to the web server (the web server is to a standalone http server for security cameras) I was using the "virtual IP" function of a fortinet 50b for this and it worked very well via a default route to the address of the server.
