877w/ADSL2+ default gateway not set, tried all the obvious solutions
pomfmaster
Hello!
I have a fairly simple config running on my 877w and it looks alright, but somehow 'show ip route' returns 'default gateway is not set'.
I tried both 'ip route 0.0.0.0 0.0.0.0 Dialer1' and 'ppp ipcp route default', the 'default gateway is not set' problem persists either way.
It could have been a firmware issue but the previous owner had the same ISP and I did nothing but reset the router's config.
IP addresses are distributed as they should, I can access the router's server, it's just there's no WAN connection.
There's one more problem in case they may be connected: when a client is connected to the router I keep getting the 'not ecnrypted dot1x packet' error, though it doesn't terminate the connection and doesn't really do anything visible.
I'm really sorry to bother you all, but at this point I'm lost without assistance and none of my friends worked with ADSL. I would really appreciate any bit of help.
Thanks in advance,
Sincerely yours,
Eugene.
Here's the config (no NAT):
Building configuration...
Current configuration : 4127 bytes
version 12.4
no service pad
hostname %HOSTNAME%
boot-start-marker
boot-end-marker
logging queue-limit 1000
logging buffered 100000
logging reload alerts
logging rate-limit console 20
enable password ****
no aaa new-model
crypto pki trustpoint TP-self-signed-36895898
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-36895898
revocation-check none
rsakeypair TP-self-signed-36895898
crypto pki certificate chain TP-self-signed-36895898
certificate self-signed 0 []
       quit
dot11 syslog
dot11 ssid pppoverthecuckoosnest
  vlan 1
  authentication open
  authentication key-management wpa
  mbssid guest-mode
  wpa-psk ascii 0 y8AuM8RUsQc7w
no ip routing
no ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.1 192.168.0.10
ip dhcp pool vlan1
  network 192.168.0.0 255.255.255.0
  default-router 192.168.0.1
username eugene privilege 15 password 0 taurus11
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
no ip route-cache
no atm ilmi-keepalive
dsl operating-mode adsl2+
interface ATM0.1 point-to-point
description avangarddsl
no ip route-cache
pvc 0/35
pppoe-client dial-pool-number 1
interface FastEthernet0
shutdown
interface FastEthernet1
shutdown
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 mode ciphers tkip
broadcast-key vlan 1 change 30
mbssid
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Vlan1
no ip address
no ip route-cache
bridge-group 1
interface Dialer1
ip address negotiated
no ip redirects
no ip unreachables
ip virtual-reassembly
encapsulation ppp
dialer pool 1
dialer-group 1
no keepalive
no cdp enable
ppp authentication pap callin
ppp pap sent-username ptn password 0 ptn
interface Dialer0
no ip address
ip mtu 1452
ip tcp adjust-mss 1452
interface BVI1
ip address 192.168.0.1 255.255.255.0
ip forward-protocol nd
ip http server
ip http secure-server
snmp-server community public RO
control-plane
bridge 1 protocol ieee
bridge 1 route ip
line con 0
no modem enable
line aux 0
line vty 0 4
login local
scheduler max-task-time 5000
end
interface Dialer0
ip nat outside
interface BVI1
ip nat inside
access-list 99 permit 192.168.0.0 0.0.0.255
ip nat inside source list 99 interface Dialer0
Regards.
Alain
7 Replies 7
paolo bevilacqua
With IP routing enabled,  "default gateway" will never be set, because that applies to hosts, not routers.
That is not a problem at all, andevertying works fine using "default route" instead of "default gateway".
Then if no Internet connection, shart checking "shjow dls interface" and then various other show commands.
Oh, I see.
Thanks a lot! That does mean that there's more digging to go through, though, because there's still no internet connection!
show dsl interface:
ATM0
Alcatel 20190 chipset information
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.5 (ADSL2+) Annex A
ITU STD NUM:     0x03                            0x2
Chip Vendor ID:  'STMI'                          'IFTN'
Chip Vendor Specific:  0x0000                    0x71C4
Chip Vendor Country:   0x0F                      0xB5
Modem Vendor ID: 'CSCO'                          '    '
Modem Vendor Specific: 0x0000                    0x0000
Modem Vendor Country:  0xB5                      0x00
Serial Number Near:    FCZ131412EB
Serial Number Far:
Modem VerChip ID:        C196 (0)
DFE BOM:         DFE3.0 Annex A (1)
Capacity Used:   45%                             100%
Noise Margin:    21.0 dB                         19.5 dB
Output Power:    18.5 dBm                        12.5 dBm
Attenuation:     28.0 dB                         13.0 dB
Defect Status:   None                            None
Last Fail Code:  None
Watchdog Counter: 0x22
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00
Interrupts:      230961 (0 spurious)
PHY Access Err:  0
Activations:     1
LED Status:      ON
LED On Time:     100
LED Off Time:    100
Init FW:         init_AMR-3.0.014_no_bist.bin
Operation FW:    AMR-3.0.014.bin
FW Source:       embedded
FW Version:      3.0.14
                 DS Channel1      DS Channel0   US Channel1       US Channel0
Speed (kbps):             0             5472             0               764
Cells:                    0               37             0            382656
Reed-Solomon EC:          0                7             0                 0
CRC Errors:               0                0             0                 0
Header Errors:            0                0             0                 0
Total BER:                0E-0           0E-0
Leakage Average BER:      0E-0           0E-0
Interleave Delay:         0               12             0                48
Bitswap:               enabled            enabled
Bitswap success:          0                   0
Bitswap failure:          0                   0
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 4 5 6 7 8 8 9 9 9 9
010: 9 8 8 8 9 9 9 9 9 9 9 8 8 8 8 8
020: 0 0 2 2 2 3 4 5 5 6 6 7 7 7 7 8
030: 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8 8
040: 8 8 7 8 8 2 8 8 8 8 7 7 7 7 7 7
050: 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7 7
060: 7 7 7 7 7 7 7 7 7 7 7 7 7 7 0 7
070: 7 7 7 7 7 7 7 7 7 7 7 6 6 2 0 0
080: 2 2 6 6 6 6 6 6 6 6 6 6 6 6 6 6
090: 5 6 5 5 5 6 6 6 6 6 5 5 5 5 5 6
0A0: 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5
0B0: 5 5 5 5 5 5 5 5 5 5 5 5 0 5 5 0
0C0: 5 5 5 5 5 5 5 5 5 5 5 4 5 4 4 4
0D0: 4 5 4 4 4 5 4 4 4 5 4 5 4 4 5 4
0E0: 5 4 4 4 4 4 4 4 5 4 4 4 4 4 4 4
0F0: 4 4 4 0 4 4 4 4 4 4 4 4 4 4 4 4
100: 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4
110: 4 4 4 4 4 4 4 4 4 4 4 4 4 4 3 3
120: 4 4 3 0 4 4 4 3 3 3 4 3 3 4 3 4
130: 3 4 3 4 3 4 3 3 4 3 3 3 3 3 3 4
140: 3 4 4 3 3 3 3 4 4 3 4 3 3 3 3 4
150: 3 3 3 3 3 3 3 3 3 3 3 3 0 3 3 2
160: 3 3 3 3 2 2 2 3 2 2 2 2 2 2 2 2
170: 3 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
180: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
190: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
1A0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 1
1B0: 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2 2
1C0: 2 2 2 2 2 2 2 2 2 2 0 1 2 2 2 2
1D0: 2 2 2 2 2 2 2 2 1 2 2 2 2 2 2 1
1E0: 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0
1F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
show dialer1:
Di1 - dialer type = DIALER PROFILE
Idle timer (120 secs), Fast idle timer (20 secs)
Wait for carrier (30 secs), Re-enable (15 secs)
Dialer state is data link layer up
Number of active calls = 0
I assume, the number of active calls being zero is a bad thing
cadet alain
you turned off ip routing:
no ip routing
but you didn't set any ip default-gateway x.x.x.x  ---> reenable ip routing:
config t
ip routing
Regards.
Alain
Oh, silly me. Of course, this may be the case :c I'll try that and report back in a second.
Thank you once again! That got rid of the gateway problem, but it seems like there's still no internet connection on the connected laptops
ip route shows:
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
     7X.0.0.0/32 is subnetted, 1 subnets
C       7X.XX.192.1 is directly connected, Dialer1
     9X.0.0.0/32 is subnetted, 1 subnets
C       9X.XX.XX.29 is directly connected, Dialer1
C    192.168.0.0/24 is directly connected, BVI1
S*   0.0.0.0/0 is directly connected, Dialer1
interface Dialer0
ip nat outside
interface BVI1
ip nat inside
Regards.
Alain
I thought I could get away without setting up NAT and access list and use them to define exclusions, but unfortunately it seems like I need it. That's really embarrasing.
I set it up just like that and added the name servers and now everything's working.
Thank you so very much, your input was more than valuable.
