881 router, mac filtering
pamirian76
hi,
I have a cisco router 881 with advipservices running ios Version 15.2(4)M1
this router is a device that the user will connect company equipement with antivirus and such.
is there a way I can force the ports like fe0 fe1 2 3 to accept only devices with specific mac addresses?
if not, is there a way for me to apply an acl to vlanX to block everything that's not from these specific addresses?
thanks in advance.
paolo bevilacqua
No, not really. Pretty much the only thing you can do is disable ARP, and setup static ARP entries.
wilson_1234_2
Level 3
Level 3
Try something like this, if the feature is available on 881:
mac-address-table secure xxxx.xxxx.xxxx FastEthernet0/1/0 vlan 70
The mac-address defined above and applied to interface f0/1/0 in vlan 70 is the only allowed traffic on the port.
That is not supported on unmanaged switches', like the ones on 800 series routers.
this can be done with a MAC acl but the acl cant be applied directly under vlan interface.
it can be applied to a bridge interface.
Router#config terminal
           bridge irb
           bridge 1 protocol ieee
           bridge 1 route ip
Router(config)#int vlan1
               no ip address
               bridge-group 1 {input-address-list 700 | output-address-list 700}
               exit
Router(Config)#int bvi1
               ip address
               exit
               access-list 700 deny 0000.0000.0000
               access-list 700 permit 0000.0000.0000 ffff.ffff.ffff
You can you refer to the below link for more details
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080100548.shtml#m
