ISR 4451-X reloading without crash logs
ashilabdulla
Hi All,
I have recently had multiple reloads on two of our routers (ISR 4451-X) installed at different sites.
I can't find any crash logs after this sudden reload. It could be a crash of the Kernel which I believe do not produce any logs.
Has anyone encountered a similar crash on any of the IOS-XE platforms?
Cheers
Ashil
6 Replies 6
Leo Laohoo
Post the output to the command "sh version".
robles2004
Hi Ashil
We had 2 routers reload without cause,  as you state there are no crash logs.  Have you made any progress in determining what caused your reload?  We are running the following bin isr4400-universalk9.03.13.00.S.154-3.S-ext.SPA.
Due to the large number of ISR4451 routers in our network, we had an internal discussion with Cisco. Unfortunately, I cannot comment on the outcome of these discussions as they are confidential.
Please raise a TAC case with Cisco and confirm with TAC whether the new replacement router (If Cisco TAC agrees to the RMA process) will not be exhibiting the same reload issue.
Cheers
Ashil.
Hi All,
Cisco TAC have advised a fix for this issue. (see below link)
However it is best to raise a ticket with Cisco TAC and follow the procedures advised by them rather than go ahead with the upgrade procedure described in the link.
http://www.cisco.com/c/en/us/td/docs/routers/access/4400/cpld/isr4400_hwfp.html#pgfId-1068031
Cheers
Ashil Abdulla
Config T
I recently experienced an unexplained reload on an ISR 4451-X. Anyone have any clues?
router#sh ver
Cisco IOS XE Software, Version 03.13.00.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.4(3)S, RELEASE SOFTWARE (fc11)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Mon 28-Jul-14 01:18 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2014 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
router uptime is 1 hour, 6 minutes
Uptime for this control processor is 1 hour, 7 minutes
System returned to ROM by reload
System restarted at 10:14:38 PST Tue Dec 16 2014
System image file is "bootflash:/isr4400-universalk9.03.13.00.S.154-3.S-ext.SPA.bin"
Last reload reason: PowerOn
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appx             None             None             None
uc               None             None             None
security         securityk9       Permanent        securityk9
ipbase           ipbasek9         Permanent        ipbasek9
cisco ISR4451-X/K9 (2RU) processor with 664304K/6147K bytes of memory.
Processor board ID xxxxxxxxx
4 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
8388608K bytes of physical memory.
15396735K bytes of flash memory at bootflash:.
router#
