07-09-2019 04:17 PM
I am setting up a lab using 3750-X and 881-W devices.
I want to setup the 3750-X as a L3 switch with the router to the internet.
The original plan is to:
no switch port on the switch port to the router
Enable IP Routing on the L3 Switch
Setup Default routes
IP Nat on router
My question is because the 881-W has a integrated L2 switch, how should/can I add the 881-W to the switch?
Thanks in advance!
Solved! Go to Solution.
07-10-2019 03:21 PM
On a side note, I think the 881-W has only one routed port, FastEthernet4. There is a GigabitEthernet port, but that is used for the connection to the embedded AP. So your config would look like below (I have not included any NAT statements). Don't forget to create Vlan 2 on the router...
881-W
interface FastEthernet0
description Downlink to 3750
switchport access vlan 2
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
description Link to ISP
ip address dhcp
duplex auto
speed auto
interface Vlan1
interface Vlan2
ip address 10.0.0.1 255.255.255.252
ip route 0.0.0.0 0.0.0.0 FastEthernet4 dhcp
3750
ip routing
interface GigabitEthernet0/1
description Uplink to 881-W
switchport mode access
interface Vlan2
ip address 10.0.0.2 255.255.255.252
ip route 0.0.0.0 0.0.0.0 10.0.0.1
07-09-2019 04:31 PM
The lab
07-10-2019 03:21 PM
881-W
ip address dhcp
duplex auto
speed auto
interface Vlan1
interface Vlan2
3750
ip routing
interface Vlan2
07-10-2019 05:48 PM
07-09-2019 07:02 PM
Those LAN ports on the Router are Layer 2 (L2) ports.
You can configure an interface Vlan for the vlan configured on the L2 port connecting to the Switch.
Btw, nice lab!
07-10-2019 11:45 AM
Thanks Hector, so then I would create a new Vlan give it an IP, assign it to lets say port 3 which is connected to the switch and no switch port that port and give it an IP?
07-10-2019 12:22 PM - edited 07-10-2019 02:05 PM
If port 3 accepts the command no switchport (to make it Layer 3), you can then configure the IP address directly in the port and that is the IP address that will communicate with your Switch since to this interface you are connecting that Switch.
If 'no switchport' is rejected, the port is Layer 2 only and by default it belongs to vlan 1. You can modify the vlan association by running switchport access vlan X in the port configuration where X is any vlan number within the accepted range. In this case, interface vlan X is where you need to configure the IP address.
07-11-2019 07:09 AM - edited 07-11-2019 08:05 AM
I appreciate the help from both Hector and Greg. Because Greg provided a working config, i will mark his reply as the solution.
07-11-2019 08:37 AM
