881W router issue - credentials
gavin han
I'm having issue with 881W router. this router doesnt let me logon to it after I restart the router and enter correct credentials. after being at the router - it doesn't let me logon to its AP module even after adding correct credentials. pls help...i've changed 2 routers so far but see same issue.
try to setup up credentials using:
username <username> priviledge 15 secret 0 <password>
or
username <username> priviledge 15 password 0 <password>
or
username <username> priviledge 15  <password>
Reza Sharifi
Have you configured the vty lines?
example:
line vty 0 4
exec-timeout 60 0
privilege level 15
password 7 0822455D0A16
login local
transport input telnet ssh
this is happening with console though. I haven't configured vty line yet since console itself has been giving problems ..
so, this is new router and you are trying to login to it for the first time?
johnlloyd_13
Level 9
Level 9
Hi Gavin,
Did u do a write memory on your device after restart and trying to login? Try adding this command on console port and try again:
line console 0
login local
