887VA - ADSL pppoe (LLC) over pots
ebostock777
Hi all,
I'm trying to configure an 887VA for a pppoe ADSL2+ connection with no luck.
I know the ISP requires pppoe (LLC), and the pvc is 8/35.
The CD light is on, and the line is up, but the 887 just won't connect....
Any help would be very much appreciated!!
Below is my current config:
version 15.1
boot-start-marker
boot-end-marker
no aaa new-model
ip source-route
ip cef
no ip domain lookup
ip domain name ***
no ipv6 cef
license udi pid C887VA-W-A-K9 sn FTX160785UU
controller VDSL 0
ip ssh version 2
interface ATM0
no ip address
no atm ilmi-keepalive
pvc internet-vc 8/35
  tx-ring-limit 3
  oam-pvc management
  encapsulation aal5snap
  pppoe-client dial-pool-number 1
interface Ethernet0
no ip address
shutdown
no fair-queue
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
no ip address
interface Vlan1
description LAN
ip address 192.168.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Dialer1
description Commander DSL
ip address ****** 255.255.255.0
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname ***********@ppp.onestream.com.au
ppp chap password 0 ******
ppp ipcp dns request
ppp ipcp address accept
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source route-map nat_isp interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended nat_acl
permit ip 192.168.0.0 0.0.0.255 any
deny   ip any any
dialer-list 1 protocol ip permit
no cdp run
route-map nat_isp permit 10
match ip address nat_acl
match interface Dialer1
mavespig
Level 3
Level 3
remove from the dialer 'ppp authentication chap callin' and ' ppp ipcp address accept' which are not needed, then enable 'debug ppp negotiation' and collect the logs.
check also on 'show dsl interface atm 0', to confirm that the line trained up.
Marco
ebostock777
The above code works, the problem was with the ISP.
ebostock777
All working.
