asr and portchans
johnelliot6
Level 2
Level 2
Hi Guys,
Just testing an ASR1000 ->2960 portchan w/ test subint on asr  and vlan int on 2960 in same vlan, and Im unable to pass any packets with my "usual" config (7200->2960)...portchan comes up, and I see 2960 mac, but cannot ping.  If I change the setup to use physical Int (i.e. gie1/0/0 as trunk, then gi1/0/0.88 as subint) it works fine?
i.e. not working:
ASR
interface Port-channel1
description ETHCHAN_TO_ESW
mtu 1998
no ip address
ip flow ingress
no negotiation auto
interface GigabitEthernet1/0/0
no ip address
ip flow ingress
negotiation auto
no cdp enable
channel-group 1
interface GigabitEthernet2/0/0
no ip address
ip flow ingress
negotiation auto
no cdp enable
channel-group 1
interface Port-channel1.88
description TEST
encapsulation dot1Q 88
ip address 10.10.10.1 255.255.255.252
no ip proxy-arp
Router#sh interface port-channel 1
Port-channel1 is up, line protocol is up
  Hardware is GEChannel, address is f0f7.5548.50c0 (bia f0f7.5548.50c0)
  Description: ETHCHAN_TO_ESW
  MTU 1998 bytes, BW 2000000 Kbit, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Keepalive set (10 sec)
    No. of active members in this channel: 2
        Member 0 : GigabitEthernet1/0/0 , Full-duplex, 1000Mb/s
        Member 1 : GigabitEthernet2/0/0 , Full-duplex, 1000Mb/s
Router#ping 10.10.10.2
Sending 5, 100-byte ICMP Echos to 10.10.10.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
Router#
Router#
Router#
Router#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.10.10.1              -   f0f7.5548.50c0  ARPA   Port-channel1.88
Internet  10.10.10.2             31   0019.06d9.7541  ARPA   Port-channel1.88
Is there something different needed on the ASR for this setup, or am I seeing a potential bug?
Using the following XE on the ASR:  System image file is "bootflash:/asr1000rp1-adventerprisek9.02.01.01.122-33.XNA1.bin"
Cheers.
johnelliot6
Level 2
Level 2
Hi - just to reply to my own post, found the following link http://www.cisco.com/en/US/docs/ios/lanswitch/configuration/guide/lsw_cfg_gecvlan_ps9587_TSD_Products_Configuration_Guide_Chapter.html
Which works:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/2 ms
Router#show interfaces port-channel 1 etherchannel
All IDBs List contains 2 configured interfaces
  Port: GigabitEthernet2/0/0 (index: 0)
  Port: GigabitEthernet1/0/0 (index: 2)
Active Member List contains 2 interfaces
    VLAN 1 (Sec, St, D, P)    VLAN 88 (Pri, Ac, C, P)
    VLAN 1 (Pri, Ac, D, P)    VLAN 88 (Sec, St, C, P)
Passive Member List contains 0 interfaces
Bucket Information for VLAN Manual LB:
    Bucket 0   (p=GigabitEthernet2/0/0, s=GigabitEthernet2/0/0) active GigabitEthernet2/0/0
    Bucket 2   (p=GigabitEthernet2/0/0, s=GigabitEthernet1/0/0) active GigabitEthernet2/0/0
    Bucket 8   (p=GigabitEthernet1/0/0, s=GigabitEthernet2/0/0) active GigabitEthernet1/0/0
    Bucket 10   (p=GigabitEthernet1/0/0, s=GigabitEthernet1/0/0) active GigabitEthernet1/0/0
Router#sh etherchannel load-balancing
EtherChannel Load-Balancing Method:
    vlan-manual
but I would prefer load-balancing over the 2 portchan members to be automatic, not have to config them on a per-vlan basis?
