891FW Configuration Not Working
lyonadmiral
The Verizon Fiber connection is not offered with a static IP, which is fine, so I've configured the WAN Gig8 interface to use DHCP.  I can ping by IP or DNS externally from the router.
I'm having trouble configuring the internal interfaces; in my tinkering with the dhcp pool devices connected to Gig0-7 either get an IP or they don't, but when they do get an IP they can't connect to devices outside.
Am I forgetting a step? NAT pool?
Would appreciate any help... Thank you.
8 Replies 8
TheGoob
Not sure this is of any relevance but this was my 891F config… I did have a block of 6 usable IPS and was using PPPoE but maybe the NAT and what not will be of assistance.
891f
hostname CiscoHOM
boot-start-marker
boot-end-marker
aqm-register-fnf
no logging console
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
ip name-server 205.171.3.65
ip name-server 205.171.2.65
ip cef
no ipv6 cef
parameter-map type inspect global
log dropped-packets enable
max-incomplete low 18000
max-incomplete high 20000
vpdn enable
vpdn-group 1
license udi pid C891F-K9 sn FGL212791GJ
username <username> privilege 15 password 0 <password>
class-map type inspect match-all INSIDE-TO-OUTSIDE-CLASS
match access-group name INSIDE-TO-OUTSIDE
class-map type inspect match-all OUTSIDE-TO-INSIDE-CLASS
match access-group name OUTSIDE-TO-INSIDE
policy-map type inspect INSIDE-TO-OUTSIDE-POLICY
class type inspect INSIDE-TO-OUTSIDE-CLASS
inspect
class class-default
drop
policy-map type inspect OUTSIDE-TO-INSIDE-POLICY
class type inspect OUTSIDE-TO-INSIDE-CLASS
pass
class class-default
drop
zone security INSIDE
zone security OUTSIDE
zone-pair security IN-TO-OUT source INSIDE destination OUTSIDE
service-policy type inspect INSIDE-TO-OUTSIDE-POLICY
zone-pair security OUT-TO-IN source OUTSIDE destination INSIDE
service-policy type inspect OUTSIDE-TO-INSIDE-POLICY
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0
description Home Wireless
no ip address
zone-member security INSIDE
interface GigabitEthernet1
description Email Server
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
description PPPoE xDSL WAN
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
no cdp enable
interface Vlan1
ip address 207.108.121.182 255.255.255.248
ip virtual-reassembly in
interface Async3
no ip address
encapsulation slip
interface Dialer1
description PPPoE xDSL WAN Dialer
ip address negotiated
no ip unreachables
ip mtu 1460
zone-member security OUTSIDE
encapsulation ppp
ip tcp adjust-mss 1420
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname <hostname>
ppp chap password 0 <password>
ppp pap sent-username <username> password 0 <password>
ppp ipcp route default
no cdp enable
ip forward-protocol nd
ip http server
ip http authentication local
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list extended INSIDE-TO-OUTSIDE
permit ip host 207.108.121.176 any
permit ip host 207.108.121.177 any
permit ip host 207.108.121.178 any
permit ip host 207.108.121.179 any
permit ip host 207.108.121.180 any
permit ip host 207.108.121.181 any
permit ip host 207.108.121.182 any
permit tcp host 207.108.121.180 any
permit tcp host 207.108.121.180 any eq smtp
permit tcp host 207.108.121.180 any eq 993
permit udp host 207.108.121.177 any eq domain
permit udp host 207.108.121.180 any eq domain
permit udp host 207.108.121.182 any eq domain
ip access-list extended OUTSIDE-TO-INSIDE
permit icmp any host 207.108.121.176
permit icmp any host 207.108.121.177
permit icmp any host 207.108.121.178
permit icmp any host 207.108.121.179
permit icmp any host 207.108.121.180
permit icmp any host 207.108.121.181
permit icmp any host 207.108.121.182
permit udp any host 207.108.121.180 eq domain
permit udp any host 207.108.121.177 eq domain
permit udp any host 207.108.121.182 eq domain
permit tcp any host 207.108.121.180 eq 993
permit tcp any host 207.108.121.180 eq smtp
dialer-list 1 protocol ip permit
no cdp run
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
I didn't spot the section in the config where it shows your NAT?
share the config you test
MHM
lyonadmiral
LMC#show run
Building configuration...
Current configuration : 2170 bytes
version 15.4
service config
hostname LMC
boot-start-marker
boot-end-marker
enable secret 5 $1$S8mF$rYL3N5NzVHTUnDirzJPD..
enable password Ku3c9xfr1981!
no aaa new-model
service-module wlan-ap 0 bootimage autonomous
ip dhcp pool internal-pool
network 192.168.254.0 255.255.255.0
default-router 192.168.254.1
dns-server 8.8.8.8 8.8.4.4
ip cef
no ipv6 cef
license udi pid C891FW-A-K9 sn FJC2016L1ZM
interface BRI0
no ip address
encapsulation hdlc
shutdown
no ip address
shutdown
duplex auto
speed auto
ip dhcp client lease 1 0 0
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
description Uplink to Verizon FIOS
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Wlan-GigabitEthernet8
no ip address
interface wlan-ap0
no ip address
interface Vlan1
description Internal Connections
ip address dhcp
interface Async3
no ip address
encapsulation slip
no ip http server
snmp-server community public RO
control-plane
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
stopbits 1
line 3
modem InOut
speed 115200
flowcontrol hardware
line vty 0 4
password Republic1!
login
transport input none
scheduler allocate 20000 1000
end
Ip nat outside under interface connect to ISP that OK
But where is ""ip nat inside""
Also vlan1 must be the gw for use' and you dont assign IP to it?
You need to assign IP to vlan (same IP you use in dhcp pool as defualt router) and add ip nat inside under vlan1
And config NAT pool' you sure missing it.
MHM
TheGoob
It appears you have no ZONES configured, INSIDE or OUTSIDE
Seeing as you have no 'dialer1' you may have to use your GE8... But more so, I wonder, do you need 'ip nat inside' on your VLAN1?
I would try that first.. 'ip nat inside' on vlan1
inspect
class class-default
drop
pass
class class-default
drop
no ip address
no ip address
interface Vlan1
interface Dialer1
no ip unreachables
ip mtu 1460
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
Friend the router work without add zone' it all traffic between interface by defualt.
We add later zone for more security
MHM
Max Jobs
Hi there,
It sounds like you might be missing a configuration step for Network Address Translation (NAT) on your router. NAT is essential for allowing devices on your internal network (connected to Gig0-7) to communicate with devices outside your network, such as the internet.
Here's a general outline of steps you might need to take:
Configure DHCP on internal interfaces (Gig0-7): Ensure that your router is correctly assigning IP addresses to devices connected to Gig0-7.
Configure NAT (Network Address Translation): This is crucial for allowing devices on your internal network to communicate with devices outside. You typically configure NAT to translate private IP addresses (used internally) to a single public IP address (used externally). This is often referred to as NAT overload or PAT (Port Address Translation).
Example configuration for NAT overload on a Cisco router:
ip nat inside source list <ACL> interface Gig8 overload
Replace <ACL> with the name or number of an access control list that identifies the internal IP addresses you want to translate.
Set up an Access Control List (ACL): This is to identify which traffic should be translated by NAT. You may want to permit traffic from your internal network to the outside world.
Example ACL configuration:
access-list <ACL> permit ip <internal-network> <subnet-mask> any
Replace <internal-network> with the IP address range of your internal network and <subnet-mask> with the appropriate subnet mask.
Apply the ACL to the NAT configuration:
This command associates the ACL with the NAT configuration, ensuring that traffic matching the ACL is subjected to NAT.
Verify configuration: After making these changes, ensure that devices on your internal network can now access devices outside (e.g., internet resources). You can also check NAT translations using the command show ip nat translations.
