9 of 100 Servers Denied SolarWinds Config Backup Job (using SSH)
WMA Hell
I have 9 of 100 network devices fail every Sunday when SolarWinds runs a config backup job. I can't ssh to them either when I run a manual SSH from Putty on the SolarWinds server. Well, 7 of the 9 are unreachable. I can ping all 9 of them.  I give up. I assume the  unreachable devices, by SolarWinds, have an older (1024) RSA crypto key but then why would I be able to manually ssh to two of them? SMH.
SSH from Jump Server/SolarWinds Server (Putty)SolarWinds Backup Job Error
Successful SSHERROR: Startup config: Connection Refused by ip
Successful SSHERROR: Startup config: Connectivity issues, discarding configuration (or configuration is too short)
password prompt prompts more than once, failERROR: Running config: Connection Refused by ip
password prompt prompts more than once, fail-Access DeniedERROR: Running config: Connection Refused by ip
Network Error Connection RefusedERROR: Startup config: Connection Refused by ip
Network Error: Connection RefusedNetwork Error: Connection Refused
Remote side unexpectedly close network connectionERROR: Startup config: Connection Refused by ip
Device Platforms
FTD
Cisco C1000
Cisco C1101-40P
Cisco 3945
Cisco 1101-4P
Cisco 2960
Cisco 2960
Cisco C1101-4P
marce1000
  - When the SSH fails from the Solarwinds host , then check the logs on the switch  .
 M.
balaji.bandi
Fix this issue - connect the device and check the Logs, any SSH issue or any ACL ? make sure username and password correct to login ?
compare working device vs not working device see the difference, that give indication to fix the issue
BB
