900 ISR DHCP WAN gi5 port No Internet
T0mTheCat
Hi!
Current network has Asus router connect to ISP Modem, local network is working ok.
Cisco Router connected to the local network switch -> router WAN port gi5
I am trying to test if the gi5 WAN port on dhcp is working
I could not ping from router to 8.8.8.8
R1(config)#int gi5
R1(config-if)#do ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 0 percent (0/5)
interface GigabitEthernet3
switchport access vlan 20
switchport mode access
no ip address
interface GigabitEthernet4
ip address dhcp
duplex auto
speed auto
interface GigabitEthernet5
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan20
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface GigabitEthernet5 overload
ip nat inside source list list1 interface GigabitEthernet5 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet5 dhcp
ip access-list standard list1
permit any
access-list 1 permit 0.0.0.0 255.255.255.0
What did I miss?
Much appreciate your assistance! Thank you!
5 Accepted Solutions
balaji.bandi
NVI0 192.168.2.1 YES unset up up
Vlan1 unassigned YES unset down down
Vlan20 192.168.2.1 YES manual down
You got 2 IP address Overlapping
for testing
interface Vlan20
No ip address 192.168.2.1 255.255.255.0
ip address 192.168.3.1 255.255.255.0
ip nat inside
no shutdown
no access-list 1 permit 192.168.2.0 255.255.255.0
access-list 1 permit 192.168.3.0 255.255.255.0
Test - post ping results 8.8.8.8 along with below details ?
sho ip nat statistics
Show IP nat translation
Show ip route
show ip access-list
BB
Hello
I think you need to check the physical connectivity between asus and rtr1 i see you have two switches interconnected
Also why are you setting the wan interface of rtr1 to dhcp - is the asus supposed to be providing address allocation for rtr1 ?
lastly remove the static route from the rtr1 that static route relating to the svi 250 on the rtr1 so it isn’t required
Confirm the physical connectivity please
Kind Regards
Paul
The output of show ip interface brief shows G5 using DHCP but with no IP address learned. That would also explain why default routes using G5 are not being installed in the IP routing table. We need to figure out the issue with DHCP on this interface.
Rick
T0mTheCat
Hi @Richard Burts and @paul driver
Thank you so much! After I plug Cisco router gi5 direct to the TPLink Switch, it works!
Now, I can ping and tracert 8.8.8.8 from the PC plug to the Cisco switchport gi3
I cant get to any website or internet, i believe DNS or NAT is causing the issue?
Here is my config
ip dhcp pool pool1
import all
network 192.168.250.0 255.255.255.0
dns-server 75.75.75.75 ---> 8.8.8.8 it works now!!!
default-router 192.168.250.1
ip cef
no ipv6 cef
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
switchport access vlan 250
no ip address
no ip address
shutdown
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan250
ip address 192.168.250.1 255.255.255.0
ip nat inside
no ip http server
no ip http secure-server
ip route 0.0.0.0 0.0.0.0 dhcp
access-list 1 permit 192.168.250.0 0.0.0.255
Much appreciate everyone help! =D
And hope this can help someone using 900 ISR
Thanks for the update. On some devices no switchport does work and some devices it does not. So it looks like your device does not support this and you will need to assign interfaces to a vlan, configure the vlan interface to provide L3 functionality, and assign IP address to the vlan interface.
Rick
23 Replies 23
balaji.bandi
Try change below config :
no ip nat inside source list list1 interface GigabitEthernet5 overload
no ip access-list standard list1
no access-list 1 permit 0.0.0.0 255.255.255.0
see if that works ?
Also post show ip interface brief after change done and still not working.
BB
Hi BB,
Thank you for replying!
GigabitEthernet0 unassigned YES unset down down
GigabitEthernet1 unassigned YES unset down down
GigabitEthernet2 unassigned YES unset down down
GigabitEthernet3 unassigned YES unset down down
GigabitEthernet4 unassigned YES manual down down
GigabitEthernet5 unassigned YES DHCP up up
balaji.bandi
for testing
interface Vlan20
ip nat inside
no shutdown
Show ip route
show ip access-list
BB
Hi BB,
Test Ping
R1(config)#int gi5
R1#sho ip nat statistics
*Oct 15 02:01:20.840: %SYS-5-CONFIG_I: Configured from console by console
Total active translations: 0 (0 static, 0 dynamic; 0 extended)
Peak translations: 0
Outside interfaces:
GigabitEthernet5
Inside interfaces:
Vlan20
Hits: 0 Misses: 0
CEF Translated packets: 0, CEF Punted packets: 0
Expired translations: 0
Dynamic mappings:
-- Inside Source
[Id: 2] access-list 1 interface GigabitEthernet5 refcount 0
Total doors: 0
Appl doors: 0
Normal doors: 0
Queued Packets: 0
=\\ no output
R1#Show ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
a - application route
+ - replicated route, % - next hop override, p - overrides from PfR
Gateway of last resort is not set
R1#show ip access-list
Standard IP access list 1
10 permit 0.0.0.0, wildcard bits 255.255.255.0
Vlan20 192.168.2.1 YES manual down down
Thank you =]
the access list 1 is wrong, you need to use a wildcard mask (see line marked in bold). What is GigabitEthernet5 actually connected to, the ISP modem, the ASUS ?
no ip address
ip address dhcp
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan20
ip nat inside
ip http server
--> access-list 1 permit 192.168.2.0 0.0.0.255
Hi Georg,
Thanks for replying!
GigabitEthernet5 is connected to local network switch.
Asus is the router connected to the ISP modem in local network on DHCP.
** Correction - SG90D-05 is a Cisco hub, not switch.
interface Vlan20
ip nat inside
ip http server
I tried your suggestion, still no connection.
it was suggested by Balaji before that appparently, the ASUS is dishing out 192.168.2.0/24 addresses, which overlap with the IP addressing of Vlan 20. Did you change that ? Use the exact config below:
no ip address
ip address dhcp
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan20
--> ip address 192.168.3.1 255.255.255.0
ip nat inside
ip http server
--> access-list 1 permit 192.168.3.0 0.0.0.255
Hi Georg,
Yes I did, but still  no connection.
no ip address
ip address dhcp
shutdown
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan20
ip nat inside
ip http server
can you ping anything on the Vlan 20 network from the ASUS ? Try and ping 192.168.3.1 from the ASUS, does that work ?
Hi George,
All 5 packet failed
I tried both gi3 and gi5
make sure that ASUS has a route back to the 192.168.3.0/24 network. You probably have to add a static route to this network on the ASUS.
Hello
@Georg Pauwen  You wouldnt wont to apply a static route on the Asus for a network that suppose to be hidden by NAT from the ISR rtr
@T0mTheCat Suggest before you apply any NAT in fact remove it completely from the ISR router and then once removed test you connectivity from the ISR towards the Asus, make sure you have connectivity to/from the rtrs before you append any NAT.
Kind Regards
Paul
Hi Paul,
I did try setting it manually, however I still cant get any PING from the ASUS router to Cisco Router.
ip address 192.168.2.7 255.255.255.0
duplex auto
speed auto
Hi Georg,
So I reset the router and redo abit, however I still cant get any ping even from the ASUS router to Cisco Router
! Last configuration change at 09:14:07 UTC Fri Oct 16 2020
version 15.8
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 25
ip dhcp pool pool1
ip cef
no ipv6 cef
redundancy
no ip address
no ip address
no ip address
no ip address
no ip address
shutdown
duplex auto
speed auto
ip address dhcp
ip nat outside
duplex auto
speed auto
interface Vlan1
no ip address
interface Vlan250
ip nat inside
no ip http server
ip route 192.168.250.0 255.255.255.0 192.168.2.1
R1#show ip route
Gateway of last resort is not set <---------- not sure why my gateway is not set, i tried ip route 0.0.0.0 0.0.0.0 192.168.2.1 as well
192.168.250.0/24 is variably subnetted, 2 subnets, 2 masks
C 192.168.250.0/24 is directly connected, Vlan250
L 192.168.250.1/32 is directly connected, Vlan250
