A systematic 10 second latency on a WAN link with nat
ashley_dew
I am having a problem while connecting servers on a remote site with an exact 10 second latency(ping is normal also smtp has the 10 sec latency). On the local LAN, the response is immediate. Furthermore, on the remote site, the servers are natted on the Internet.
Here is the topology.
Site A RouterA 3845 <-Gi0/1 ---------------------------------Gi0/1-> Site B RouterB 3845---->Internet FA0/0/0(vlan 1)
fa0/0/0 vlan1 LAN A -10.100.10.0/24                                                        Gi0/0  LAN B 10.100.1.0/24
--->Internet vlan 2 fa0/0/1
The WAN link is a 100 Mbps wireless link and the connection on a IPSEC over GRE link.
Router A
interface Vlan1
description LAN EMMAUS
ip address 10.100.10.1 255.255.255.0
ip nat inside
interface Vlan2
description Connexion Internet
bandwidth 512
ip address  xxxx 255.255.255.0
ip access-group RESTRICTION-ENTREE-INTERNET in
ip nat outside
interface GigabitEthernet0/1
description ***Connection to Site B
bandwidth 100000
ip address 10.100.13.130 255.255.255.128
duplex auto
speed auto
media-type rj45
no mop enabled
crypto map vpn-port
interface Tunnel21
description *** Tunnel A to B
bandwidth 100000
ip address 172.16.2.1 255.255.255.252
tunnel source GigabitEthernet0/1
tunnel destination 10.100.13.129
ip mtu 1356
router ospf 1
router-id 10.100.10.1
log-adjacency-changes
redistribute static
network 10.100.10.0 0.0.0.255 area 10
network 172.16.1.0 0.0.0.3 area 0
network 172.16.1.4 0.0.0.3 area 0
network 172.16.1.8 0.0.0.3 area 0
network 172.16.2.0 0.0.0.3 area 0
ip nat inside source list ACCESS-INTERNET interface Vlan2 overload
ip route 0.0.0.0 0.0.0.0 196.2.10.10
ip access-list extended ACCESS-INTERNET
permit ip host 10.100.10.42 any
permit ip host 10.100.10.50 any
permit ip host 10.100.10.51 any
permit ip host 10.100.10.52 any
Router B
interface GigabitEthernet0/0
description ***LAN B ***
ip address 10.100.1.252 255.255.255.0
ip accounting output-packets
ip nat inside
duplex auto
speed auto
media-type rj45
no mop enabled
description *** Connection to EMMAUS  link ***
bandwidth 100000
ip address 10.100.13.129 255.255.255.128
duplex auto
speed auto
media-type rj45
no mop enabled
crypto map vpn-port
interface Vlan1
description *** Connection to VSAT ***
bandwidth 512
ip address xxxxx 255.255.255.248
ip access-group CONNEXION-ENTRANTE-VSAT in
ip nat outside
crypto map vpnmap -- > For external VPNs remote access
interface Tunnel21
description *** Tunnel  B - A ***
bandwidth 100000
ip address 172.16.2.2 255.255.255.252
tunnel destination 10.100.13.130
ip mtu 1356
router ospf 1
router-id 10.100.1.252
redistribute static subnets
network 10.100.1.0 0.0.0.255 area 1
network 172.16.3.0 0.0.0.3 area 0
network 172.16.3.4 0.0.0.3 area 0
network 172.16.3.8 0.0.0.3 area 0
ip nat pool prxy-pool xxxxx36 xxxxxx36 netmask 255.255.255.248
ip nat inside source static tcp 10.100.1.5 8181 interface Vlan1 8181
ip nat inside source static tcp 10.100.1.46 80 interface Vlan1 80
ip nat inside source route-map PROXY-MAP pool prxy-pool overload
ip nat inside source static 10.100.1.25 xxxxx.37
ip route 0.0.0.0 0.0.0.0 xxxxx.33
The 10.100.1.25 is a mail server.
When I try from LAN A to telnet 10.100.1.25 25, the response is 10 second for 220 reply. However, ssh, ping are immediate. The ip mtu has been reduced to 1356 byte to compensate for IPSEC over GRE mode.
On LAN B, the response to port 25 on the same server is immediate.
I am suspecting a NAT configuration on Router B.
Could you please help.
Ashley
paolo bevilacqua
That may be very well a problem with the server, however on the LAN interface facing the mail server, try
ip tcp adjust-mss 1316
