aaa authentication login default group radius local command?
CiscoBrownBelt
Level 11
Level 11
Just trying to confirm some things with the below command. Are the group names configured on your actual ACS or Radius server that you are using? If you only have one default group in there or 1 group that is when you can just specify Radius below correct?
Cristian Matei
    The AAA server name convention is locally significant, it doesn't need to match between the NAD and the NAS. What you're seeing on the CLI, referencing an AAA server in your AAA commands by the keyword of "radius"/"tacacs" or by the AAA server group name, like a group named MY_RADIUS_SERVERS, has to do with the AAA architecture evolution on the IOS side. Historically speaking:
         1. Initially, long time ago, you would define your AAA servers globally, via radius/tacacs specific command configuration, and in order to reference these in your authentication,authorizatio,accounting commands, you would use the radius/tacacs keyword in order to point to the globally defined servers. For example:
aaa new-model
radius-server host 1.1.1.1 key ciscoradius
tacacs-server host 2.2.2.2 key ciscotacacs
aaa authentication login default group tacacs+ local
aaa authorization network default group radius
aaa session-id common
     2. Afterwards, in order to allow VRF-aware AAA and make the AAA architecture more scalable (for example allow to group your AAA servers, instead of globally configuring all of them and not being able to reference just some), the AAA group server feature was added.
NON-vrf aware configuration still requires the key to be configured globally, so you would configure the AAA server both globally to define the key, and at the AAA group level to specify which of the globally defined servers you're using:
aaa new-model
tacacs-server host 5.5.5.5 key ciscotacacs
tacacs-server host 6.6.6.6 key ciscotacacs
radius-server host 3.3.3.3 key ciscoradius
radius-server host 4.4.4.4 key ciscoradius
aaa group server radius ALL_RADIUS
 server 3.3.3.3
aaa group server tacacs+ ALL_TACACS
 server 5.5.5.5
aaa authentication login default group ALL_TACACS local
aaa authorization network default group ALL_RADIUS
If you want VRF-aware AAA, one of the reasons for which AAA grouping was allowed, you configure everything under the AAA group, you no longer need servers to be the globally defined, you can specify the key at the group level:
aaa new-model
 server-private 3.3.3.3 key ciscoradius
 server-private 4.4.4.4 key ciscoradius
 ip vrf forwarding AAA
 server-private 5.5.5.5 key ciscotacacs
 server-private 6.6.6.6 key ciscotacacs
  3. Finally, what you should be using today, which gives you total control and scalability over your AAA configuration is to define each of your AAA server independently, reference which server(s) you need into which AAA server groups, and reference the AAA server groups in your authentication/authorization/accounting commands:
radius server FIRST_RADIUS
 address ipv4 7.7.7.7
 key ciscoradius
radius server SECOND_RADIUS
 address ipv4 8.8.8.8
 key ciscoradius
tacacs server FIRST_TACACS
 address ipv4 9.9.9.9
 key ciscotacacs
radius server SECOND_TACACS
 address ipv4 10.10.10.10
 key ciscotacacs
 server name FIRST_RADIUS
 server name SECOND_RADIUS
aaa group server radius ALL_TACACS
 server name FIRST_TACACS
 server name SECOND_TACACS
Cristian Matei.
5 Replies 5
balaji.bandi
as per my understand you are kind of correct. (since we dont know full configuraiton hard to say the outcome)
instead i suggest some reference :
https://community.cisco.com/t5/security-documents/aaa-sample-config/ta-p/3143393
BB
Richard Burts
I do not fully understand the question, especially this part
"If you only have one default group in there or 1 group that is when you can just specify Radius below correct?"
but the other part of the question is more clear
"Are the group names configured on your actual ACS or Radius server that you are using?"
and the answer is that the group names used in the device configuration do not need to match anything in the ACS or Radius server.
Rick
Cristian Matei
aaa new-model
aaa new-model
 server 3.3.3.3
 server 5.5.5.5
aaa new-model
 key ciscoradius
 key ciscoradius
 key ciscotacacs
 key ciscotacacs
Cristian Matei.
Awesome. So basically if I only have 1 AAA server, I don't have to create an actual group I can just use the
"aaa authentication login default group radius local" command correct?
     Yes, you can, that would be option number one. However, those commands are legacy, will be remove soon, and on newer IOS'es you get a similar warning about it. This also means that if you hit a bug, you'll be told to update your AAA configuration which will possibly fix the issue. I would recommend option 3, even if it's a single RADIUS server, but option 1 should still work at the same time, with stated drawbacks.
Cristian Matei.
