Access-List limitations on ASR920
We have multiple Layer 2 MPLS networks deployed with Cisco ASR920 routers. We have issues matching/denying traffic on ACLs. We tried 3 options
1. Applying the ACL inbound on the physical interface closest to the source - Doesn't match anything
2. Applying the ACL inbound on the service-instance inside the physical interface closest to the source - Clashes with QoS on the physical interface
3. Applying the ACL inbound on the "interface bdi" matches traffic only sourced from a local physical interface, not coming inbound via a pseudowire
I have attached a diagram which shows all three scenarios. Access-List Issue.png
9 Replies 9
Hello
Can you confirm if the ACL is a extended access list?
Kind Regards
Paul
Yes, it is a regular extended Layer 3 ACL matching IPs.
Tested a few more scenarios and the only thing that works is if I apply the ACL on the service instance and remove the QoS service-policy.
the traffic is not routing so ACL can not apply here.
you need some kind of L2 ACL link
Mac ACL
port ACL
Vlan ACL <<- this must be sure that you run VLAN in PW.
The traffic is Layer 3, routing out of the BD using the "int BDI" on the left side router. In the lab, when I tested the ACL on the physical interface, I generated traffic from the router.
On our projects, we have actually deployed the ACL inbound on the interface bdi, but this works only if the traffic is originated from a local from a local physical interface, not when it is coming over a pseudowire from another router.
Tested a few more scenarios. Looks like, on this platform, with our design, the only way to successfully have ACLs is on the interface inside the service instance. But then you cannot apply a QoS service-policy for marking on the same interfaceAccess-List Issue.png
mlund
Level 7
Level 7
If your goal is to deny traffic based on acl, then you can do it this way
specify the acl, make a class-map that match the acl, make a policy-map with the just made class-map, in the class-map set qos-group. apply the policy on input interface.
Make a new class-map that match the qos-group from above, make a new policy-map, in the class-map set police <value> conform action drop exceed action drop, apply policy-map to the outgoing interface.
I have done it this way, work as a charm for denying mDNS
Interesting idea, thanks
I think I found the solution here.
you use Port-ACL ??
