Access-list problem
Kevin Cummins
Level 2
Level 2
Hello all,
I am having an issue with access lists on an ASA..
Not too familiar with ASA's, but the I can't ping from the internal network to another network I have set by static route.
Pinging to an item in the other network is fine from the local ASA.
Below  is the config and packet tracer output:
interface Ethernet0/0
no nameif
no security-level
no ip address
interface Ethernet0/1
nameif outside
security-level 0
pppoe client vpdn group EDIT-PPP
ip address 222.222.222.44 255.255.255.255 pppoe setroute
interface Ethernet0/2
nameif inside
security-level 100
ip address 10.102.4.250 255.255.255.0
interface Ethernet0/2.1
vlan 1
nameif internal
security-level 100
no ip address
interface Ethernet0/3
nameif checkpoint
security-level 100
no ip address
interface Management0/0
nameif management
security-level 100
management-only
ftp mode passive
dns server-group DefaultDNS
domain-name test.com
same-security-traffic permit inter-interface
object network inside-net
subnet 10.102.4.0 255.255.255.0
object network vpn-subnets
subnet 10.1.0.0 255.255.0.0
access-list nonat extended permit ip 10.102.4.0 255.255.255.0 10.1.0.0 255.255.0.0
pager lines 24
logging enable
logging trap informational
logging history notifications
logging asdm informational
mtu management 1500
mtu outside 1454
mtu inside 1500
mtu internal 1500
mtu checkpoint 1500
no failover
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-522.bin
no asdm history enable
arp timeout 14400
nat (inside,outside) source static inside-net inside-net destination static vpn-subnets vpn-subnets
nat (inside,outside) dynamic interface
route inside 10.1.0.0 255.255.0.0 10.102.4.1 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication telnet console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
telnet 192.168.1.0 255.255.255.0 management
telnet timeout 5
ssh 192.168.1.0 255.255.255.0 management
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
vpdn group EDIT-PPP request dialout pppoe
vpdn group EDIT-PPP localname
[email protected]
vpdn group EDIT-PPP ppp authentication pap
vpdn username
[email protected]@test.com
password *****
dhcpd dns 10.102.4.15 222.222.222.1
dhcpd wins 10.102.4.15 10.1.10.5
dhcpd address 192.168.1.2-192.168.1.254 management
dhcpd enable management
dhcpd address 10.102.4.30-10.102.4.199 inside
dhcpd domain test.com interface inside
dhcpd enable inside
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
webvpn
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns preset_dns_map
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
  inspect icmp
service-policy global_policy global
prompt hostname context
call-home reporting anonymous prompt 2
packet-tracer input inside icmp 10.102.4.128 0 8 10.1.10.80
Phase: 1
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
Additional Information:
MAC Access list
Phase: 2
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10.1.0.0        255.255.0.0     inside
Phase: 3
Type: ACCESS-LIST
Subtype:
Result: DROP
Config:
Implicit Rule
Result:
input-interface: inside
input-status: up
input-line-status: up
output-interface: inside
output-status: up
output-line-status: up
Action: drop
Drop-reason: (acl-drop) Flow is denied by configured rule
MCSE, MCTIP, VCP6-DV, CCNP, CWNA, Cisco Meraki Solutions Specialist
paolo bevilacqua
Wrong forum, post in security. You can move your post using the actions panel on the right.
Do you mean from Internal as in the sub interface 0/2.1 ? to inside as interface 0/2 ?
Inside, as in interface 0/2
There is another router on the inside interface that I am trying to route users to. (at 10.102.4.1)
Both the clients and router are connected via the same switch. (Not L3)
Like this:
           ASA
         Switch
    Clients    Router
I have no access to change the settings on the other router.
I can ping it from this ASA, but can get client traffic to go.
Do I need a same security traffic permit intra interface command in there?
