Accessing remote network via dedicated Point-to-Point
t3st1ng5678
I was recently informed that we require a dedicated point-to-point T1 circuit with a business partner. They are handling the circuit and are managing the routers at my location, but I need to know how to allow machines on my internal network to access resources across this new dedicated point-to-point circuit.
My existing network is setup as follows -
There are two T1's coming into two separate routers:
- From router A, an ethernet cables plugs into the back of a loadbalalancer device.
- From router B, an ethernet cable plugs directly into a switch on VLAN1.
- The loadbalancer has an ethernet cable plugging into VLAN1 as well.
- The PIX firewall is also plugged into VLAN1. The PIX uses the loadbalancer as the default gateway to access the internet.
- All internal machines reside behind the firewall and are using the firewall's internal IP as their gateway.
I currently have several site-to-site connection on my firewall, therefore its imperative that my internal machines continue to use this as their gateway. Also, I would like to put a firewall behind the routers for this dedicated circuit to protect my internal resources from their network.
Please let me know what options I should explore.
Adam Frederick
Level 3
Level 3
In order for your internal PCs to access resources across this dedicated line, your clients default gateway needs to know how to route to the new destination. So you will need a static route or use a dynamic routing protocol. Simple as that.
As for setting up another firewall, depending on what model router & IOS you have, just set it up there.
So since the default gateway for my client PC's is my PIX 515E firewall, I would add a static route there to direct traffic intended for this business partner over the dedicated point-to-point T1?
If so, from the router of the dedicated cirtuit on my end, what would I need to do so that it can cimmunicate with my PIX?
balajitvk
Level 4
Level 4
I don't think you need to add static route all your machines. Since all your machines are behind pix you can do the routing there itself.
If you add a static route in the pix with destination network as you partner network and gateway as the router where you terminated the t1 link of your partner.
