03-05-2006 05:25 AM - edited 03-03-2019 11:56 AM
Can anyone explain ,why the control field in the 802.3 format and PPP frame format is 03..?
Thanks in advance..
03-05-2006 06:37 AM
Search for LLC Type 1 and you should find what your after.
03-05-2006 09:25 PM
The Control feild in 802.3 is having command, response, and sequence number informations. If you want you can refer this link,
http://www.cisco.com/en/US/tech/tk331/tk336/technologies_tech_note09186a0080094777.shtml#control
The contro field in ppp is a constant value 00000011 (3 decimal). If you want you can refer this link,
http://www.tcpipguide.com/free/t_PPPGeneralFrameFormat.htm
Rgs,
