loss of BGP community attribute
att-sgcops
I have 2 routers running BGP:
R7 config~~~~~~~~~~~~~~~~~~~~~~~~~~~
router bgp 700
redistribute connected route-map t1
neighbor 20.20.20.5 remote-as 500
neighbor 20.20.20.5 send-community
route-map t1 permit 10
set community no-export
but from the BGP table, I cannot see the "no-export" attribute:
R7#sh ip bgp 6.6.6.6
BGP routing table entry for 6.6.6.6/32, version 2
Paths: (1 available, best #1, table Default-IP-Routing-Table)
Advertised to non peer-group peers:
20.20.20.5
Local
0.0.0.0 from 0.0.0.0 (8.8.8.8)
Origin IGP, metric 0, localpref 100, weight 32768, valid, sourced, best
R7#
why I cannot see it?
att-sgcops
the whole config, some parts may be no relavalent.
R7#sh run
Building configuration...
Current configuration:
! Last configuration change at 10:17:02 UTC Tue Apr 13 1993
version 12.1
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname R7
class-map chris
match none
class-map COS2_TRAFFIC
match none
ip subnet-zero
ip domain-list ccnp.com
ip domain-list ccna.com
ip domain-name ccie.com
ip name-server 10.1.1.1
ip name-server 10.1.1.2
ip name-server 10.1.1.3
tag-switching tdp router-id Loopback7
cns event-service server
interface Loopback0
ip address 7.7.7.7 255.255.255.255
interface Loopback1
ip address 6.6.6.6 255.255.255.255
interface Loopback2
ip address 8.8.8.8 255.255.255.255
interface Loopback7
no ip address
interface Ethernet0/0
ip address 20.20.20.7 255.255.255.0
ip directed-broadcast
ip policy route-map vfilter
half-duplex
max-reserved-bandwidth 76
interface Serial0/0
ip address 137.20.25.1 255.255.255.0
traffic-shape group 101 64000 8000 8000 1000
interface Serial0/1
no ip address
shutdown
clockrate 64000
router bgp 700
ip classless
no ip http server
ip pim rp-address 10.1.23.3
access-list 1 permit 6.6.6.6
access-list 2 permit 7.7.7.7
access-list 3 permit 8.8.8.8
access-list 12 permit 30.1.1.5
access-list 33 permit any
access-list 101 deny udp any any range 16348 32767
access-list 101 permit ip any any
route-map setCom permit 10
match ip address 1
set community 65542
route-map setCom permit 20
match ip address 2
set community 65543
route-map setCom permit 30
match ip address 3
set community 65544
route-map setCom permit 40
match ip address 33
route-map addas permit 10
match ip address 1
set as-path prepend 777
route-map addas permit 20
match ip address 2
set as-path prepend 666
route-map addas permit 30
snmp-server engineID local xxxx
snmp-server view test snmp excluded
snmp-server community secret RW 1
snmp-server community public RO 2
snmp-server trap link ietf
snmp-server trap-source Ethernet0/0
snmp-server packetsize 512
snmp-server trap-timeout 45
snmp-server location singapore
snmp-server contact ATT
snmp-server tftp-server-list 3
snmp-server manager
tftp-server flash:c2600-js56i-mz.121-3.T.bin alias upload
voice-port 1/0/0
voice-port 1/0/1
voice-port 1/1/0
voice-port 1/1/1
line con 0
exec-timeout 0 0
privilege level 15
login
transport input lat pad v120 mop telnet rlogin udptn nasi
line aux 0
line vty 0 4
privilege level 15
login
ntp clock-period 17208882
ntp server 200.200.100.1
end
Harold Ritter
It appears that prefix 6.6.6.6/32 is originated via a network statement because of its Origin attribute being set to IGP. Can you confirm that.
If it is the case then it this normal that the community no-export is not set on this prefix since the route-map t1 is configured on the "redistribute connected" statement.
You could also use the route-map t1 on the netwrok statement to solve this issue.
Hope this helps,
now see my new configuration:
hostname R7
interface Loopback0
interface Loopback1
interface Loopback2
interface Loopback7
no ip address
half-duplex
interface Serial0/0
interface Serial0/1
no ip address
shutdown
clockrate 64000
router bgp 700
no auto-summary
ip classless
no ip http server
match ip address 1
route-map t1 permit 20
match ip address 2
set community no-advertise
route-map t1 permit 30
match ip address 3
set community local-AS
end
the Origin attribute changed to imcompleted, but still not able to see the attribute:
BGP routing table entry for 6.0.0.0/8, version 4
20.20.20.5
Local
Origin incomplete, metric 0, localpref 100, weight 32768, valid, sourced, best
R7#sh ip bgp 7.7.7.7
BGP routing table entry for 7.7.7.7/32, version 19
Flag: 0x208
20.20.20.5
Local
R7#sh ip bgp 8.8.8.8
BGP routing table entry for 8.8.8.8/32, version 20
Flag: 0x208
20.20.20.5
Local
This doesn't look normal indeed. What version of IOS is running on this box?
