01-27-2012 07:11 AM - edited 03-04-2019 03:02 PM
I am trying to test and setup some ACL's on a switch, the current setup is:
Core Switch - HP ProCurve 2610-24-PWR
Edge Switch - HP ProCurve 2510-24
VLANS 5, 10, 15, 20, 25, 30
I want to deny access to VLAN 5 from VLAN 20 which is are client VLAN.
Sorry for positng here but i do find the enterprise forums at HP useless and the cisco alot better!!!
01-27-2012 07:19 AM
access-list 199 deny ip x.x.x.x y.y.y.y where x.x.x.x is vlan 20 subnet and y.y.y.y is vlan 5 subnet, don't forget the correct wildcard mask.
then under int vlan 20: ip access-group 199 in
Regards.
Alain
02-02-2012 01:56 PM
Thanks, so would it be like this:
access-list 199 deny ip 10.4.20.0 10.4.5.0
then go into vlan 20 by doing:
and then that should be it on the edge switch?
02-03-2012 03:37 AM
When I input access-list i get this:
XXXX-g21-2510g-24-1(config)# access-list
Invalid input: access-list
this is on the 2510
02-03-2012 12:50 PM
the config I gave was for a Cisco device I didn't even read that you had HP devices but the concepts remain the same.
there should be a configuration guide for your device downloadable from HP.
Regards.
Alain
02-03-2012 12:52 PM
lol thanks.
I think I managed to get it working, I configured it on the core and it all works but when I go to an edge switch and ping a IP Address in a VLAN i've set to deny on the core it can still ping it, I plug back into core and it works..............do I need to do anything on the edge switch or the trunk on the core?
02-03-2012 03:41 PM
This could happen if the edge switch also has layer 3 interfaces / SVIs. In that case the traffic from a user A on Vlan 5 hits the edge switch, which routes it to vlan 20, and out goes the traffic to user B on Vlan 20, completely bypassing the core -switch. This could happen even if one SVI was in the Edge, the the ACLs on the core interfaces were not applied in both directions.
To resolve this, if your edge switch has both vlans as layer 3, apply acls there as well, else apply an acl on edge switch vlan and core switch vlan as well.
