Med attribute bgp
sarahr202
Level 5
Level 5
Hi everybody.
Please consider the following example:
     AS1                                 AS2
R1--199.199.199.0----R2----200.200.200.0----R3
In the above fig, R1 and R2 are in AS 1 and R3 is in AS2.
R1 is advertising its loopback address 10.10.10.10/8 to R2 via ibgp.
Below is the  path atributes of prefix 10.0.0.0 advertised by R1(1.1.1.1) to R2 (2.2.2.2) via ibgp.
No.     Time        Source                Destination           Protocol Info
     75 435.902000  1.1.1.1               2.2.2.2               BGP      UPDATE Message
Frame 75 (97 bytes on wire, 97 bytes captured)
Cisco HDLC
Internet Protocol, Src: 1.1.1.1 (1.1.1.1), Dst: 2.2.2.2 (2.2.2.2)
Transmission Control Protocol, Src Port: 50780 (50780), Dst Port: bgp (179), Seq: 65, Ack: 65, Len: 53
Border Gateway Protocol
    UPDATE Message
        Marker: 16 bytes
        Length: 53 bytes
        Type: UPDATE Message (2)
        Unfeasible routes length: 0 bytes
        Total path attribute length: 28 bytes
        Path attributes
            ORIGIN: IGP (4 bytes)
            AS_PATH: empty (3 bytes)
            NEXT_HOP: 1.1.1.1 (7 bytes)
            MULTI_EXIT_DISC: 0 (7 bytes)
            LOCAL_PREF: 100 (7 bytes)
        Network layer reachability information: 2 bytes
Next R2  learns the prefix 10.0.0.0/8 and advertises it via ebgp to R3. Below is the path attributes of the prefix as advertised by R2 to R3
One thing which is missing is MED.  R2  does not include the med when it advertises a ibgp-learned prefix to its Ebgp peer R3.
Is this normal ?
     14 35.035000   200.200.200.2         200.200.200.3         BGP      UPDATE Message
Frame 14 (87 bytes on wire, 87 bytes captured)
Cisco HDLC
Internet Protocol, Src: 200.200.200.2 (200.200.200.2), Dst: 200.200.200.3 (200.200.200.3)
Transmission Control Protocol, Src Port: 13919 (13919), Dst Port: bgp (179), Seq: 20, Ack: 20, Len: 43
    UPDATE Message
        Marker: 16 bytes
        Length: 43 bytes
        Total path attribute length: 18 bytes
        Path attributes
            AS_PATH: 1 (7 bytes)
            NEXT_HOP: 200.200.200.2 (7 bytes)
I noticed that when  a router advertises its prefix which is locally generated -----  network x.x.0.0 " or redistributed into bgp----, router advertises such prefix to its ebgp peer with med attribute.
For example, R3 is advertising prefix 40.0.0.0/8 which is configured on its loopback, to its ebgp peer R2 with med attribute.
Below is the packet capture :
    223 729.950000  200.200.200.3         200.200.200.2         BGP      UPDATE Message
Frame 223 (94 bytes on wire, 94 bytes captured)
Cisco HDLC
Internet Protocol, Src: 200.200.200.3 (200.200.200.3), Dst: 200.200.200.2 (200.200.200.2)
Transmission Control Protocol, Src Port: bgp (179), Dst Port: 13919 (13919), Seq: 248, Ack: 272, Len: 50
    UPDATE Message
        Marker: 16 bytes
        Length: 50 bytes
        Total path attribute length: 25 bytes
        Path attributes
            AS_PATH: 2 (7 bytes)
            NEXT_HOP: 200.200.200.3 (7 bytes)
            40.0.0.0/8
May I conclude from the above:
A router does not include med attribute when advertising ibgp-learned prefix to its ebgp peer.  A router will include med attribute when advertising a locally generated bgp prefix----the prefix entered bgp table via network or redistribute--- to its ebgp peer
  thanks and have a great weekend.
Peter Paluch
Hello Sarah,
What you observed is correct. According to BGP RFC 4271:
                                                     If received over
   EBGP, the MULTI_EXIT_DISC attribute MAY be propagated over IBGP to
   other BGP speakers within the same AS (see also 9.1.2.2).  The
   MULTI_EXIT_DISC attribute received from a neighboring AS MUST NOT be
   propagated to other neighboring ASes.
So the MED can be either set on locally injected routes, in which case it will be propagated over iBGP and eBGP, or it can be set on networks received from another AS, in which case it will be propagated only via iBGP but will be stripped away when advertising prefixes further via eBGP. The reason is clear: the MED is an indication to a neighboring AS which entry point it is supposed to use when sending traffic back to us. However, this recommendation has no meaning past the neighboring AS and therefore must be stripped.
Best regards,
Peter
Peter Paluch
Hello Sarah,
                                                     If received over
Best regards,
Peter
