ACL list on routing interface BGP
Evert0505
Good day,
I have 2 connected switches over a p2p link using BGP.
we want to only allow connection to the internet (Public IP ranges) and some internal network ports to be exposed. However, the below test is not working at all. All the matches are on the BGP point-to-point interfaces and traffic is getting true.
I want to block all traffic to and from 172.22.201.52
Interface configuration:
interface Ethernet1/41.100
description xxxx
encapsulation dot1q 100
ip access-group test1 in
ip access-group test1 out
vrf member xxxx
ip address 172.22.193.100/31
no shutdown
IP access list test1
statistics per-entry
10 deny ip any 172.22.201.52/32 [match=0]
11 deny ip 172.22.201.52/32 any [match=0]
90 permit ip 172.22.193.0 0.0.0.255 172.22.193.0 0.0.0.255 [match=24770]
Thank you in advance,
Evert
7 Replies 7
Jon Marshall
Not sure what you are trying to do.
If you want to block all traffic to and from 172.22.193.0/24 why do you have a permit line for that subnet in your acl ?
Jon
Can you more elaborate ?
Evert0505
Thanks for the fast response! I did change the treat.
There is a BGP session running on the same interface so that need's to get true.
But to make it more clear I want to block 172.22.201.52. However, if I ping it I can see that it got a hit on :  90 permit ip 172.22.193.0 0.0.0.255 172.22.193.0 0.0.0.255
So you don't want to block 172.22.193.0/24 ?
I am still not really understanding what you are trying to do.
If you are able to ping 172.22.201.52 where are you pinging it from in relation to the interface you have applied the acl to ?
Jon
I'm very sorry, I think I found the problem if you do something like this you should also apply it on the second switch in order to get it working and do a full test.... Sorry for your time!
I will upload my full ACL list so at least someone who is working on ACL lists can use it!
Hello
Can you post the output of the following please:
sh ip bgp sum
sh ip bgp
sh ip route bgp
Kind Regards
Paul
Evert0505
Goodmorning, Bellow the full list and this is working.
Allowing a BGP connection on the interface subnet /24 as I'm doing another switch I did add another range as well (172.22.193.0 and 172.22.194.0)
This is blocking any private IP address and allowing the devices to go to any public IP addresses (Inet)
  description interface
  ip access-group Acceslist in
  vrf member x
  no shutdown
Object groups
IPv4 address object-group BGPpeer
        10 172.22.193.0 0.0.0.255
        20 172.22.194.0 0.0.0.255
IPv4 address object-group loopback1
        10 172.22.192.0 0.0.0.255
IPv4 address object-group private
        10 192.168.0.0 0.0.255.255
        20 172.18.0.0 0.15.255.255
        30 10.0.0.0 0.255.255.255
ACL list
IP access list Acceslist
        100 remark allow acces to Loopback subnet
        101 permit ip any addrgroup loopback1
        102 permit ip addrgroup loopback1 any
        940 remark Allow BGP peer
        941 permit ip addrgroup BGPpeer addrgroup BGPpeer
        950 remark Deny all Private IP ranges (RFC1918)
        951 deny ip addrgroup private any
        1000 remark Allow any Public Ip ranges
        1001 permit ip any any
 Thank you all for the help. If you have questions about this, just let me know.
