ACL Problem
harrisgirls
Hello Chaps,
I got a guest vlan 193 ... i put acl's on vlans before no worries when i  do it to this one if i put for example (extended rule deny ip  10.193.0.0 0.0.255.255 10.1.0.102 0.0.0.0.) 10.1.0.102 is a file server  it blocks the ping but also stops dns working :/ im confused !!
DNS for everything that is any external lookup's
the strange thing is the acl works but the DNS Stops .....
even though the DNS is pointing externally and i have tried putting a permit all rule after the deny and still doesnt work ....
any help?
Jon Marshall
It will stop DNS, it will stop all IP traffic because you have a "deny ip ..." statements.
try -
deny icmp  10.193.0.0 0.0.255.255 10.1.0.102 0.0.0.0
Jon
jyoung
There is an implicit deny at the end of every acl. Are you adding permits for the traffic you need to get through?
