ACL Specific Prefix Question
Iloveyou
In the ACL list
10 permit icmp 10.0.0.0/8 host y.y.y.y
The above line does not work UNLESS I use a more specific subnet which in this case is 10.1.1.0/24.
So I have to put the line below.
10 permit icmp 10.1.1.0/24 host y.y.y.y
Can someone explain to me why the more general subnet mask will not work?
Isnt the 10.0.0.0/8 subnet supposed to include all the 10 subnet?
7 Replies 7
You are totally correct' the 10.0.0.0/8 must work BUT it can other issue effect this traffic.
One of them is NATing
Other is Routing
Can you share the config and topolgy let me check it
MHM
10.1.1.1/24 is configured on my laptop.
This is no other network since I just configured the subnet on my laptop for testing purposes only.
1-NAT issue
debug ip nat
2-routing issue
in ACL add in end
deny any any log
this will give you hint if it not routing issue, if traffic pass through other interface
MHM
balaji.bandi
Can you explain more what is not work ? that permit statement - what is y.y.y.y (is part of that  that supernet ?)
what devices is this /X  should use wild mask for the ACL to accept ?
BB
y.y.y.y is the specific ip address of the destination host.
As of now I am using a laptop for testing.
what is /X should sue subnet mask?
You need to post more configuration here and give us the device mode and IOS code running
how these connected ?
10 permit icmp 10.0.0.0/8 host y.y.y.y   - this not work from your Laptop are you not able to ping this y.y.y.y ? where is y.y.y.y connected. ? how is your topology looks like ?
BB
This is the configuration, it is a C1111 router
line vty 0 4
access-class TESTACL in
privilege level 15
login local
transport input ssh
ip access-list extended TESTACL
10 permit ip 10.0.0.0 0.0.0.255 host 10.0.0.3
interface Vlan3
ip address 10.0.0.3 255.255.255.0
interface GigabitEthernet0/1/3
switchport access vlan 3
switchport mode access
The topology is that I connect my laptop to Gi0/1/3 with ip address 10.0.0.2/24 configured.
The ACL : 10 permit ip 10.0.0.0 0.0.0.255 host 10.0.0.3 works.
But 10 permit ip 10.0.0.0 0.255.255.255 host 10.0.0.3 doesnt work.
Any specific reason?
I dont know. maybe i got my subnet mask wrong.
