ACL to deny telnet from the open internet
bsciarra1
Good morning, I need to configure an acl that blocks telnet access from an internet-facing router.
I think I want to do something like this:
access-list 102 deny tcp any any eq telnet
But I read a single deny entry will have the effect of implicitly denying all traffic not explicitly permitted.
How would i write this acl to only deny telnet access from the open internet but continue to allow everything else?
Brian
Edison Ortiz
access-list 102 permit ip any any
7 Replies 7
Edison Ortiz
Hi - this is interesting and I'm just learning about ACL's for my CCNA test.
Would this ACL be applied on the internet router's public side WAN interface like this. My example uses serial 0/0 as the public interface on this router.
conf t
interface serial 0/0
ip access-group 102 in
Patrick
Yes that access list would logically be applied inbound on the router's internet facing interface. The result would be that any attempt to telnet to any address inside the network, including any address on the internet router, would be denied and all other traffic would be permitted.
Rick
Rick
Thanks Guys,
I tried to picture this as if I'm a tech inside the network, and I need all of my internal subnets to have telnet access to the router, but I want to block all outside traffic from telnetting in.
Thank you for the info!
access-list 102 permit tcp [local_subnet] any eq telnet
Thank you i applied this acl accordingly it appears to be working.
