ACL traffic flow
tangt1
Using packet tracer to test ACLs. I have a router int g0/0 connecting to LAN 10.1.1.0/24. On same router i have g0/1 connecting to LAN 11.1.3.0/24. I confirmed hosts in each LAN are able to ping across networks. I then placed an ACL (out) on interface g0/0. ACL is working as it is denying traffic from source ip 11.1.3.0/24 to 10.1.1.0/24. However I am unable to ping from hosts on 10.1.1.0/24 to hosts on 11.1.3.0/24. Do i need a ACL (in) on int g0/0 as well to allow traffic from 10.1.10/24 to 11.1.3.0/24?
10 deny 11.1.3.0 0.0.0.255
20 permit any
7 Replies 7
Hello
Just to confirm you wish to deny 11.1.3.0/24 users from accessing 10.1.1.0/24 but you wish 10.1.1.0/24 users to be able access 11.1.3.0/24?
Kind Regards
Paul
Correct. ACL works in denying 11.1.3.0/24 users to 10.1.1.0/24. However users in 10.1.1.0/24 can't communicate with 11.1.3.0/24 users. IE: unable to telnet or ping into a switch on 11.1.3.0/24 from host on 10.1.1.0/24
To allow one network to initiate traffic to another network and to receive responses from the second network while not allowing the second network to initiate traffic to the first network is a challenge. The optimum solution is to have some device that does a stateful inspection (such as a firewall) and ACL is not a stateful firewall.
The most simple alternative works for TCP (Only) traffic is using the "Established" traffic in the ACL but it is not supporting in PT.
access-list 101 permit tcp <source> <mask> <destination> <mask> established
So finally, it is not possible with PT.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hello
try the example below:
access-list 100 permit tcp 11.1.3.0 0.0.0.255 any established
access-list 100 deny ip 11.1.3.0 0.0.0.255 any
access-list 100 permit ip any any
this will only allow establishied tcp return traffic too 10.1.1.0. from 11.1.3.0 but allow 10.1.1.0 to communicate
Int c/c
ip access-group100 out
another way would possibly use a reflective acl
Kind Regards
Paul
Hi @paul driver
He is using PT and it is not supported on PT. :)
Deepak Kumar,
@Deepak Kumar
Packet tracer has limited feature set so I am not at all surprised however the actual acl example would work on proper software
Kind Regards
Paul
Just to add to what the others have noted, don't know if PT supports, but reflexive ACLs support simple state. For example, an outbound ping would allow the ping reply yet an outside ping, or "unknown" ping reply would be blocked. This is a bit better than using EST flag alone and works for non-TCP traffic too.
