ACL
alaeldien
Hello
access-list 100 deny tcp any host 192.168.1.100 eq 80
int fa 0/0 # ip access-group 100 out
is it the correct ACL to prevent the specified host from internet.
if not, could some one please correcting this.
thank you
Istvan_Rabai
Level 7
Level 7
Hi Ahmed,
This acl denies any outbound access to a web server under ip address 192.168.1.100.
To deny access of a specific host to any http service on the Internet:
access-list 100 deny tcp host 192.168.1.100 any eq 80
"int fa 0/0 # ip access-group 100 out"
This is OK if fa 0/0 is the Internet-facing interface.
Cheers:
Istvan
Hi Ahmed
and also dont forget the permit any at the end of the ACL, as any access list has a deny any statment at the end.
so as below
access-list 100 permit ip any any
Giuseppe Larosa
Hello Ala,
nice to hear from you
be aware that TCP port 80 stays on the server side.
if f0/0 is your internal lan
int f0/0
ip access-group 100 in
if f0/0 is the WAN port (to internet)
int f0/0
the well known port follow the server side and you need to permit something or the ACL will deny everything.
Hope to help
Giuseppe
