ACS routing question
richardcalvert
I have some routers at remote locations that Im trying to get talking with my new ACS server. All the IP's we use are public, so when I tell the router to talk to ACS at 201.x.x.x, which is behind my ds3, its actually going to 201.x.x.x in another country. My question is this; what would be the best way to get my routers pointed to the correct 201.x.x.x address?
sdrossen2
Just to clarify, your using a public ip (201.x.x.x) internally that is not assigned to you?
Correct. It's actually private behind our ds3, but our private IP's match public IP's.
also, the routers that have the 201.x.x.x IP addresses are behind gateways with static IPs.
So I need the private 201.x.x.x addressed routers to communicate with the private 201.x.x.x ACS server.
