Add "NEW" GigabitEthernet on router | Packet Tracer 7.3.1
Fotit
I try to build a OSPF Lab
Routers (like 2901) has two ports G by default, but i need to add two other ports (G)
so i insert two  HWIC-1GE-SFP, then power on the router
When i attempt to plug cable, i see only the defaults ports !!
The new ports are "on", i don't understand the problem?
If you have answer please.
2 Accepted Solutions
Martin L
Probably a bug in this version of PT;  Lots of issues or 7.3 on MACs and Linux. what is your OS ?
btw.  PT 8 is out now ; you should use PT 8 from now on !
Regards, ML
**Please Rate All Helpful Responses **
it used to be that the only PT router you could add another L3 interface to was the 4331. You need to add a GLC-T to the empty slot in the lower right corner (there are four empty slots). I have attached a file with two 4331 routers, each with an additional interface.
If you need more, I think your only option is to use a 3650 and make the ports 'no switchport' ports...
5 Replies 5
Martin L
Regards, ML
Ok thanks Martin
My OS is w10
So i try to use PT v8
I installed PT v8
But the problem still exists !
look at joined captures
I don't know how to diagnose this issue !!
it does NOT work for me either; I guess, they still did not fix it;  I send report to PT people to fix this. thanks for pointing out.
Regards, ML
