Adding Access List
pablo.arcelcr
I'm trying to an entry to a access list as follows:
access-list 22 permit 10.154.5.21
After I run a sh run | i access-list 22
it doesn't show the access list entry i just addded
access-list 22 remark ****** VTY Access ACL ******
access-list 22 permit 10.107.34.72
access-list 22 permit 10.64.32.12
access-list 22 permit 10.64.169.125
access-list 22 permit 10.195.32.35
access-list 22 permit 10.195.32.25
access-list 22 permit 10.195.32.24
access-list 22 permit 10.124.127.0 0.0.0.31
access-list 22 permit 10.195.127.0 0.0.0.31
access-list 22 permit 10.199.127.0 0.0.0.31
access-list 22 permit 10.68.127.0 0.0.0.31
access-list 22 deny any log
What could nbe the issue?
Predrag Jovic
Level 3
Level 3
Issue is that statement is added at the end of the list (statement is denied since deny any is listed above your new statement
% Access rule can't be configured at higher sequence num as it is part of the existing rule at sequence num X
You can see statement numbers when show access-list is issued.
Generally you have two choices. You can place statement between already existing statements
ip access-list standard 22
 <sequence number> permit 10.154.5.21
Or delete and recreate access-list:
no access-list 22
Julio E. Moisa
Hi Pablo,
You should use:
access-list 22 permit host 10.154.5.21
or
access-list 22 permit 10.154.5.21 0.0.0.0
Now a new entry will be sent to the bottom so you need to move it up using sequence as crni00000 mentioned previously.
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
End result of issuing
or
is the same.
Predrag Jovic
Level 3
Level 3
no access-list 22
