problem with add ip route switch WS-C3650-24TS
eddanilo2016
hi guys
I have problem with  switch WS-C3650-24TS , when i tried add ip route x.x.x.x x.x.x.x x.x.x.x the CLI accepts the comand but when i run show running config i dont not find the route
SWITCH-CORE#show running-config
Building configuration...
Current configuration : 7607 bytes
! Last configuration change at 23:05:15 UTC Mon Jul 17 2017
version 15.2
no service pad
service password-encryption
service compress-config
hostname SWITCH-CORE
boot-start-marker
boot-end-marker
vrf definition Mgmt-vrf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
username soporte privilege 15 password 7 120A0A071D191801787B757F70
no aaa new-model
switch 1 provision ws-c3650-24ts
ip routing
ip domain-name mallplaza.com
ip dhcp excluded-address 192.168.180.1 192.168.180.10
ip dhcp pool telefonia
network 192.168.180.0 255.255.255.0
dns-server 192.168.62.19
default-router 192.168.180.1
option 150 ip 192.168.180.2
qos queue-softmax-multiplier 100
crypto pki trustpoint TP-self-signed-1002954174
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1002954174
revocation-check none
rsakeypair TP-self-signed-1002954174
crypto pki certificate chain TP-self-signed-1002954174
certificate self-signed 01
3082022B 30820194 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 31303032 39353431 3734301E 170D3137 30373131 31393536
34325A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D31 30303239
35343137 3430819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100D1E8 64BC5EB8 2C853267 ED0E9696 3EA9AB2B 2F102187 C413C7DD 3AFE153A
DB24F350 7B58ECD8 087ECC08 3BEEE1E2 437EF763 60E490C3 E4D8ACB3 D6EB2AB5
8A927E35 AAF830F6 2C0C149E C11175E5 BFE31C43 9EB2374E 7C8006C7 D5CDF9D4
DD66219A C7D48249 51AC3269 83989B65 D8C5DA64 5746DD35 B37ED9D4 7B99FA70
FCDB0203 010001A3 53305130 0F060355 1D130101 FF040530 030101FF 301F0603
551D2304 18301680 149C0B2A 179F6451 1FC56FBC A5C6A1FD 5CDF05A9 4D301D06
03551D0E 04160414 9C0B2A17 9F64511F C56FBCA5 C6A1FD5C DF05A94D 300D0609
2A864886 F70D0101 05050003 81810090 C8C40C41 B8356BC8 64F89241 C255C027
E553BA4B 74B9C8A3 B0D2956F 9C1917C3 BB21C7C0 2692AF45 3DAF5860 76A810FF
5D6EB3D8 C3200CCA 5512B406 9157AA21 E649FAE7 1784A282 E5116DB4 4D760E37
12AB7914 DCA92DC0 451501AA 9FFE710D 67429BBD 04397F35 6E7D9D3B BC52AC84
986A7F17 9A6BB98F 832B2FEF FC7CA2
quit
diagnostic bootup level minimal
spanning-tree mode pvst
hw-switch switch 1 logging onboard message level 3
redundancy
mode sso
class-map match-any non-client-nrt-class
interface Port-channel2
description conexion troncal a SWITCH-ACCESO1
switchport mode trunk
spanning-tree portfast trunk
interface Port-channel3
description conexion troncal a SWITCH-ACCESO2
interface GigabitEthernet0/0
vrf forwarding Mgmt-vrf
no ip address
negotiation auto
interface GigabitEthernet1/0/1
description conexion router isr bogota
no switchport
ip address 192.168.61.9 255.255.255.252
interface GigabitEthernet1/0/2
description conexion a juniper
no switchport
ip address 192.168.61.5 255.255.255.252
interface GigabitEthernet1/0/3
description conexion a router claro chile
no switchport
ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet1/0/4
description conexion servidores
switchport mode access
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
description conexion CIMC - server telefonia
switchport voice vlan 100
interface GigabitEthernet1/0/10
description conexion pto 2 server telefonia
switchport trunk allowed vlan 1,100
interface GigabitEthernet1/0/11
description conexion access points
switchport trunk native vlan 63
switchport trunk allowed vlan 4,64
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
channel-group 2 mode active
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
channel-group 3 mode active
interface GigabitEthernet1/0/24
interface GigabitEthernet1/1/1
interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface Vlan1
description servidores
ip address 192.168.62.1 255.255.255.0
interface Vlan63
description gestion
ip address 192.168.63.1 255.255.255.0
interface Vlan64
description wifi
ip address 192.168.64.1 255.255.255.0
ip helper-address 192.168.62.19
interface Vlan65
description usuarios
ip address 192.168.65.1 255.255.255.0
interface Vlan100
ip address 192.168.180.1 255.255.255.0
no ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip route 0.0.0.0 0.0.0.0 192.168.61.6
ip route 10.1.0.0 255.255.254.0 192.168.60.12
ip route 10.12.0.0 255.255.254.0 192.168.60.12
ip route 10.13.0.0 255.255.254.0 192.168.60.12
ip route 10.15.0.0 255.255.254.0 192.168.60.12
ip route 10.20.0.0 255.255.254.0 192.168.60.12
ip route 10.181.9.0 255.255.255.0 192.168.60.12
ip route 10.181.10.0 255.255.255.0 192.168.60.12
ip route 192.168.102.0 255.255.255.0 192.168.61.10 name .10-isr-bogota
ip route 192.168.104.0 255.255.255.0 192.168.61.10
ip route 192.168.109.0 255.255.255.0 192.168.61.10
ip route 192.168.114.0 255.255.255.0 192.168.61.10
ip route 192.168.137.0 255.255.255.0 192.168.60.12
ip route 192.168.150.0 255.255.255.0 192.168.61.10
ip route 192.168.191.0 255.255.255.0 192.168.61.10
ip ssh authentication-retries 2
ip ssh version 2
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login local
transport input ssh
line vty 5 15
login local
transport input ssh
wsma agent exec
profile httplistener
profile httpslistener
wsma agent config
wsma agent filesys
wsma agent notify
wsma profile listener httplistener
transport http
wsma profile listener httpslistener
transport https
ap group default-group
end
SWITCH-CORE#
SWITCH-CORE#show inventory
NAME: "c36xx Stack", DESCR: "c36xx Stack"
PID: WS-C3650-24TS , VID: V04 , SN: FDO2106E3TU
NAME: "Switch 1", DESCR: "WS-C3650-24TS-L"
PID: WS-C3650-24TS-L , VID: V04 , SN: FDO2106E3TU
NAME: "Switch 1 - Power Supply B", DESCR: "Switch 1 - Power Supply B"
PID: PWR-C2-250WAC , VID: V03 , SN: DCB2108D07Y
assuming you are running the LAN Base feature set, you are probably running into the below limitation:
Switches running the LAN base feature set support 16 user-configured static routes, in addition to any default routes used for the management interface.
7 Replies 7
Philip D'Ath
What is the exact command you are trying to add?
What software version is the switch running?
for example
I am adding an IP route  in the switch core the CLI accepts the command but when i run show running config I don't find the IP route that I added., I can not add more routes
this is the version of switch
SWITCH-CORE#show version
Cisco IOS Software, IOS-XE Software, Catalyst L3 Switch Software (CAT3K_CAA-UNIV ERSALK9-M), Version 03.06.06E RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Sat 17-Dec-16 00:22 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2015 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.
(http://www.gnu.org/licenses/gpl-2.0.html) For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
BOOTLDR: CAT3K_CAA Boot Loader (CAT3K_CAA-HBOOT-M) Version 3.56, RELEASE SOFTWAR E (P)
SWITCH-CORE uptime is 14 hours, 54 minutes
Uptime for this control processor is 14 hours, 57 minutes
System returned to ROM by reload
System image file is "flash:packages.conf"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
License Level: Lanbase
License Type: Permanent
Next reload license Level: Lanbase
cisco WS-C3650-24TS (MIPS) processor with 4194304K bytes of physical memory.
Processor board ID FDO2106E3TU
5 Virtual Ethernet interfaces
28 Gigabit Ethernet interfaces
2048K bytes of non-volatile configuration memory.
250456K bytes of Crash Files at crashinfo:.
1609272K bytes of Flash at flash:.
0K bytes of Dummy USB Flash at usbflash0:.
0K bytes of at webui:.
Base Ethernet MAC Address : f8:0b:cb:e8:34:00
Motherboard Assembly Number : 73-15898-06
Motherboard Serial Number : FDO21061P4D
Model Revision Number : N0
Motherboard Revision Number : A0
Model Number : WS-C3650-24TS
System Serial Number : FDO2106E3TU
Switch Ports Model SW Version SW Image Mode
* 1 28 WS-C3650-24TS 03.06.06E cat3k_caa-universalk9 INSTALL
Configuration register is 0x102
what is the output of:
show license right-to-use usage ?
hi Pauwen
The answer given is correct
Switches running the LAN base feature set support 16 user-configured static routes, in addition to any default routes used for the management interface. The LAN base image supports static routing only on SVIs.
link
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3650/software/release/3se/routing/configuration_guide/b_rt_3se_3650_cg/b_rt_3se_3650_cg_chapter_011.html
regards
edwin velasco
Other thing I would suggest to check is the interface below and make sure it's up up:
no switchport
thank you, Georg Pauwen is correct
