ADSL Bandwidth issue
downloadkid
Firstly, sorry if my problem is a bit mundane, but I've tried everything and everywhere to try and resolve my issue so I'm hoping you gurus might be able to help!
I have a 3620 in which is a 2FE module in which is a WIC1-ADSL card. The router is running c3620-ik9o3s6-mz.123.17a.
All works as it should with a download speed a constant 843Kb/s - as it should be.
I recently purchased a 3640 so I could use larger IOS's. I swapped the FE and DSL module into the 3640. The image is c3640-ik9o3s-mz.124.8a.
All works as it should except the somehow my DSL bandwidth is capped to 300Kb/s.
I have tried several other IOS images, erased everything and started over with no success. I have even installed SDM to try and see if there are any 'default' traffic polocies in place,
attached is the startup-config, any help greatly appreciated.........
5 Replies 5
rajinikanth
Level 3
Level 3
Try to define the bandwidth manually on
interface Dialer1 using the command
bandwidth 843
Hope this will work.
Raj
Morning Raj
thanks for the suggestion..........
I specified the bandwidth manually on dialer 1, shut down the ATM0/0 interface then a no shut.
Both dialer 1 and virtual-access 2 sho a bandwidth of 850, but its still 'capped' at bang on 300Kbps.
Edison Ortiz
Have you checked for packets being fragmented ? That's usually a behavior of a DSL connection.
Please read this article on how to address packet fragmentation issues on Cisco IOS.
http://www.cisco.com/warp/public/105/pmtud_ipfrag.html
The article focuses on GRE and IPSec technology as they also fragment packets but this should also apply to DSL.
HTH,
Thanks for that, I set a tcp adjust-mss value to ensure that fragmentation was not the issue, but unfortunately it made absolutely no difference.
When I run speed tests on the net, it shows the correct download speed, around 8140 and upload around 448 - but highlights a 'throughput' of considerably less.
So there must be some sort of traffic limiting in place - but where?
downloadkid
Examining the config there is an entry;
'resource policy' - what is it? could this be the cause of the problem?
