ADSL connection speed issues
seanwaite
I have 877 ADSL router with two issues concerning my connection. My first is that my DSL provider does not provide me with a stable service. On a daily basis my connection will drop in the morning and usually reconnects at around 896kbps average. By evening time, usually after 10pm, I can reset the connection and get 3mbps. I have had technician out whose best solution was to pull the 4 ethernet cables out from the back of the 877 switch as they "probably are causing interference". So you see I don't have much hope that things will get better from the ISP's standpoint. So I have three questions I really hoping to find an answer to:
1.) In the morning I would like to restart the connection and connect at a speed of my choosing. While at the time I am connected at say 3mbps at 8am, I know for fact it will drop at any time. I would like to at my convenience restart the connection at a lower speed thus to insure the SNR is within an acceptable range at this time. However I do not know what command to use, and on which interface (assuming ATM 0). Usually it is around this time I see the SNR start to drop (though it is never high to begin with). If I could manually resync at a lower speed I am hoping that the connection would then be in acceptable margin to maintain it during the day.
2.) Is there a quick method to restart the sync? At this time I just pull the physical cable out and reset it. I have 151-4.M3. Was hoping there was a quicj and easy command to resync the connection manually through a SSH connection.
3.) If my connection always, and I mean ALWAYS, is assured to drop in the morning (between 8-9am) with average speed of 800~1mbps, but after 10 to 11pm I can reconnect at 3mbps and maintain a stable connection, does this not seem that there is some interference at my local box? I should add I do live in an apartment building. I have tried to explain this to my ISP, who while on the phone tech support seem sympathetic, the actual technicians coming out don't seem to have a clue on this. I would love to ditch this and go back to cable, but am locked in with a contract.
7 Replies 7
paolo bevilacqua
Can you post "show dsl interface".
877w#sh dsl int
ATM0
Alcatel 20190 chipset information
                ATU-R (DS)                      ATU-C (US)
Modem Status:    Showtime (DMTDSL_SHOWTIME)
DSL Mode:        ITU G.992.1 (G.DMT) Annex A
ITU STD NUM:     0x03                            0x1
Vendor ID:       'STMI'                          'IFTN'
Vendor Specific: 0x0000                          0x71C5
Vendor Country:  0x0F                            0xB5
Chip ID:         C196 (0)
DFE BOM:         DFE3.0 Annex A (1)
Capacity Used:   73%                             67%
Noise Margin:    12.0 dB                         17.0 dB
Output Power:    17.0 dBm                        12.5 dBm
Attenuation:     56.5 dB                         31.5 dB
FEC ES Errors:    0                               0
ES Errors:       68                              11
SES Errors:       0                               0
LOSES Errors:     0                               0
UES Errors:       0                               0
Defect Status:   None                            None
Last Fail Code:  None
Watchdog Counter: 0x26
Watchdog Resets: 0
Selftest Result: 0x00
Subfunction:     0x00
Interrupts:      16537 (0 spurious)
PHY Access Err:  0
Activations:     9
LED Status:      ON
LED On Time:     100
LED Off Time:    100
Init FW:         init_AMR-4.0.015_no_bist.bin
Operation FW:    AMR-4.0.015.bin
FW Source:       embedded
FW Version:      4.0.15
                 Interleave             Fast    Interleave              Fast
Speed (kbps):          3072                0           640                 0
DS User cells:       713707                0
US User & Idle cells:                              10084743                0
Reed-Solomon EC:        124                0             0                 0
CRC Errors:               0                0             0                 0
Header Errors:            0                0             0                 0
Total BER:                0E-0           0E-0
Leakage Average BER:      0E-0           0E-0
Bitswap:               enabled            enabled
LOM Monitoring : Disabled
DMT Bits Per Bin
000: 0 0 0 0 0 0 4 6 7 8 9 9 9 9 9 9
010: 9 9 9 9 8 8 8 8 8 8 8 7 7 6 5 5
020: 0 0 0 2 5 5 6 6 7 6 7 8 9 9 A A
030: A A A A A 9 A A B B B B B B B B
040: 0 B B 2 A B B A B B A A A A A A
050: A A A A A A A A A A A 9 9 9 9 9
060: 9 8 9 8 5 8 8 8 8 8 7 5 7 7 7 7
070: 7 7 3 7 7 7 7 7 6 6 6 6 6 6 6 5
080: 0 4 5 5 5 5 5 5 5 5 5 4 4 4 2 2
090: 4 2 3 3 0 2 3 3 3 3 3 3 3 2 2 2
0A0: 0 0 2 2 2 2 2 2 2 2 2 2 2 2 2 2
0B0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0C0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0D0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0E0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
0F0: 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0
DSL: Training log buffer capability is not enabled
877w#
As you have said yourself you have a poor pair, far away from CO.
http://www.kitz.co.uk/adsl/linestats.htm
http://www.dslreports.com/faq/16220
You can try another modem brand/type, but I would not expect much better of what you got now.
To force resync
conf t
int atm0
shut
no shut
^Z
If I were you, I would chase the ISP and ask for an experienced field tech in order to resolve this issue.
Show them your show dsl interface output and compare it with the field tech's reading on his tester.
Thanks for the responses. So is there a way I can set the speed on my end? Like I said in the morning I am sure to drop the connection. I would like to do this at my convenience at reconnect at a lower speed instead of waiting for it to randomly drop sometime in the morning. This way I don't have to deal with the stress of waiting to be disconnected when I am working remotely or downloading anything.
Check if yuu have "dsl snr-margin" command available, that could help.
No I don't. What I have is this:
877w(config-if)#dsl ?
  enable-training-log  enable the fw training log for Showtime and failure cases
  lom                       Loss Of Margin watch counter for line retrain
  operating-mode       auto or specific ADSL mode
  sync                      ADSL sync preferences
Assuming this command would be under ATM 0
Edit my IOS ver:
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 15.1(4)M3, RELEASE SOFTWARE (fc1)
